My first DIY here, so go easy on me. I'm not a professional, but I've done plenty of installs so here's one I just did this morning...
Install Time: ~60 minsInstall Level: 2/10Tools Needed: Flat head screw driverlong Phillips Head screw driver(10mm socket with extender optional)Wire cutters4 wire connectors or caps, or electrical tape.Beverage: 1-2 Budweisers should do ya...
Product: PolkAudio Db1000 (they are now discontinued, and have been replaced by the Db1001. Both are 1" tweeters and other brands may work, but this brand needed no alteration or modification to the stock mount for install.
http://www.crutchfield.com/S-o...B1000
Ok, here we go:There are 5 points that hold the door cover on. Each are screws/plastic locks that we will remove to access the stock tweeter. Use your flat head to remove the two plastic locks on the left.
Use the flat head again to remove the screw cover inside the door handle. Then remove the screw.
There are 2 more screws hiding behind the door grip:There is a notch at the base, use the flathead to pry off the trim.
Once off, the last 2 screws are exposed. The top is easy, but the bottom is in there pretty deep.
Now the inside door cover is free to be removed.You can now pop off the cover, start where I did, give it a good tug. Then move on to the right. Repeat till its loose. Then lift it off of the door frame.
There are now a few wires and such keeping the cover connected. No need to remove them unless you want to. Just gently rest the door down so there isn't too much stress on those wires.
Now you can see and remove the tweeter cover. Give it a tug to pop it off.
Once behind the panel you can see the stock tweeter, remove the two screws on the sides of the tweeter mount with your Phillips screwdriver.
Disconnect the tweeter from the car by lifting up that connector.
Now we want to save that mounting piece. its on there with some pretty good glue, so I used my vice. I'm sure Plyers will do just fine, but I like my vise. Once you have a good grip, remove the center screw.
Break out the new tweeters and included filter. The tweeters come with lots of mounting hardware, but you won't need any of it!
These fit right in there with no issue. Simply place the tweeters in the orignal's spot, and reinstall the stock mounting bracket. Don't reinstall that center screw.
Go back to the stock tweeter you removed, and cut the wires so we can use that connector.
Splice your wires together (White+, Black-) with the inline filter, plug the stock connector back in and test your system.
Mount your filter to the door any way you like, tape will do just fine if you're in a hurry. I simply taped mine behind the wires going to the mirror control.
Now work backwards and reinstall your door cover, move to the other side of the car, rinse wash repeat and DONE!
Crack a beer and enjoy this easy answer to the Bose lack of high frequency!
Modified by SneaKe at 9:43 PM 5/4/2008
