if i were to do something like this, i would try to stick with all nissan parts... but you can't go wrong with a 1g dsm bov! they're super reliable. when modified (the bov), they can hold well over 20#s of boost.IWannaS15 wrote:Grab a BOV from a 1st gen Eclipse/Talon.
i know the 1g dsm bov came stock on the rb20, so it's sort of a nissan part lol.DeXteR wrote:
ya i plan on doing all this on stock internals:) so only 6-8 pounds of boostDeXteR wrote:if i were to do something like this, i would try to stick with all nissan parts... but you can't go wrong with a 1g dsm bov! they're super reliable. when modified (the bov), they can hold well over 20#s of boost.
Agreed, alot of people don't give them enough credit. Cheap and they work very well, I even have one lying around. I was going to use it while I was waiting for parts to come in...I have no patience at all.Craving4Boost wrote:if you're going with a very cheap set up, why are you using upgraded injectors? you can keep the stock ones and use a FMU/RRFPR. (Fuel Management Unit/ Rising Rate Fuel Pressure Regulator).
i wanna make this buildup as cheap as possibe. basically the only thing i want to buy is the turbo manifold. i want everything to come from the junkyard. you know, just to see what happens. i figure bigger injectors will be easy to come across.Craving4Boost wrote:if you're going with a very cheap set up, why are you using upgraded injectors? you can keep the stock ones and use a FMU/RRFPR. (Fuel Management Unit/ Rising Rate Fuel Pressure Regulator).
