DIY Turbo Kit Parts?
Nick240sx
Car: 2009 Ford Fusion SE Sport
Ok so i searched and ive gotten a mix of different answers for my question, i am just suggesting a simple list here
i want to turbo the ka, now i need a good laymans list of what i need besides the turbo, intercooler ect.
anyone with good turbo set-ups in the ka please just help me out real quick here i know it may be asking alot and i know it may seem like a noob question but im tight on time here so any help is appreciated, please dont flame me, im sensitive to heat.
karmakaze
Car: 98 240sx SE
Nick240sx wrote:Ok so i searched and ive gotten a mix of different answers for my question, i am just suggesting a simple list here
out of all seriousness. this is not me just flaming you.
if you don't have the time to research it on your own, then you really probably should not do it.
the search button is your friend. and the broad question that you asked has been covered extensively.
you also might want to try http://srownersclub.com/faq/index.asp
hannibal
Car: Red Line to Glenmont
General Parts List
turboturbo exhaust manifoldwastegate (if turbo doesnt have internal wastegate swing valve housing)
downpipe (connects turbo outlet to cat/test pipe)-turbo outlet flange-piping-fittings (O2, wideband O2, EGT)-wastegate return pipe (from wastegate outlet to downpipe)--external wastegate onlytest pipe (takes place of cat, connects downpipe to catback exhaust)catback exhaust (mandrel bent)-piping-muffler
larger injectorshigh flow fuel pumpfuel management (piggyback, JWT ECU retune, hacked MAF)ignition management (timing retard control)--over 8 psi
intercooler (front mount)-IC piping (mandrel bent)-silicon hose couplers and transitions
BOV (with flange of same material as IC piping)
oil supply kit-oil pan bung-braided oil lines-oil line fittings-'T' fittings
water/coolant supply kit--watercooled turbo only
gauges-boost-oil pressure-oil temp-water temp-EGT
intake piping (mandrel bent)cone filter
gaskets-exhaust manifold-turbo flange-wastegate
vacuum hoses (silicone or rubber)-'T' fittings
clutchflywheel
SeVa-S13
Car: '05 GTO 6spd
Man, if only we had dedicated sections for this kind of stuff...
Nick240sx
iwannas15, thank you, i meant to just post a general parts list, i have one going i just dont want to leave anything out, i didnt mean to sound so clueless.
hannibal
No problem. I made that list a few years ago as I was learning all the parts. Some parts are oversimplified, but I just cut and pasted it.
I should add that Enthaply is a great source for tuned ECU's.
