macgiver »
https://forums.nicoclub.com/macgiver-u69961.html
Tue Aug 27, 2019 1:13 pm
The cooler "RETURN" in a RE4R01A , for EXAMPLE only ( my J30 trans) supplies "Rear Lubrication" - according to my ATSG auto trans manual . There is "Front Lubrication" NOT involving the cooler at all , being supplied off pressure utilized at or near the Lockup fluid ckt. Front & REAR Lubrication would be " moving parts , bearings , bushings etc. " transferring energy . Other half of fluid ckts are "control" w/ accumulators , valves, solenoids, pistons,chk valves etc. etc. which direct and actuate the different "functions" and engage things. I can only assume REAR Lubrication is less critical to a car at stand still , for your lubing the output components mostly.
But FRONT Lubrication would include input shaft , input gears?, torque converter whatever and to INTERRUPT this by diconnecting the cooler may starve something , and badly if done for a considerable length of time (like more than 60 seconds ?? )
Now it would be good to disconnect the cooler , reverse blow out into WHITE rag to inspect amount and type of debris , if any. Then while cooler is "drying out from the Brakleen or whatever was used , you may connect both loose hoses together with a 5/16? union. While refilling the pan and running the fluid out w/engine idling for 15 -20 seconds- then refill .
To "flush" more thoroughly the Converter, possibly with a big funnell and someone adding fluid while another person is under car and partially blocking the open drain hole of the pan to sort of "be in step "and have a continuous flow , In 'n Out , would probly clear out a converter in like 60 + seconds.
Of course with the disconnected cooler hose , IF fluid is coming off from the converter, would be a more thorough operation , quicker I imagine here , but how would you know how long is too long to starve the 'FRONT Lube" components ??
Also there is a "spec" for the flow of fluid going out to cooler , AND you measure before cooler the volume
"dumped" into a vessel over time vs how much less passes when going through the cooler into same pan - same time interval . Like 15 seconds 2 pints must be "passed" just the hose into pan ,and then when passing through cooler into pan you must see a minimal drop ,in the same time interval , like 1 3/4 pints now -NO LESS , for EXAMPLE . Good time to check that spec when cleaning/disconnecting cooler , or especially when adding an aftermarket cooler - some may restrict too much ( many times the bigger ones with LENGTHY tubes) so you have better cooling, BUT choking off critical lubrication!
You gotta get or see an automatic transmission manual for YOUR vehicle , they contain everything you need to know,test, maintain - whatever - your specific transmission.
