Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Sep 23, 2003 2:30 am
The usual amount of a pan drain is about 3 quarts out of 10. But we only let it drain 10-15 minutes.........so unsure what amout might drain out in a week.The term flush is sometimes confused because the flush part is the chemical cleaner whose circulation for 15 minutes removes the varnish [into solution]. When you mix oils you never know if there can be compatability issues with additives...........usually not, but without chemical analysis you never know for sure.
Even a machine exchange uses an extra 4-5 quarts to try to minimize the cross contamination.
That said I have used a combo of Toyota T4 synthetic and Mobil 1 synthetic. Even used [a couple of quarts of] conventional to stretch a limited quanity of Mobil 1 .........but I know which way the fluid comes from the machine...................last in first out more or less - but there is some mixing.
Lubeguard Red or some small amount of Black is a very good additive with any ATF brand.
