eddiec wrote:their hollow. just fill them up with stuff.
-rowman - where did you find the polyurethan construction adhesive? could you post pics of the motor mounts as well. i plan on doing those next, just wondering what they look like inside.
$2.67 a tube from Home Depot! I took pics but haven't uploaded them yet.
I basically cleaned them REAL good, then took a 3/16" drill bit and drilled into each of the mount "layers", one hole on each side. Squeeze out the fluid, wash them good to make sure the insides are free of material.
Then I plugged em full of the poly adhesive until the stuff came out the holes. Also I wedged a few scredrivers in the mount just to keep them somewhat expanded while the adhesive hardened. After I drilled the mounts and squeezed out the fluid, the mounts seemed to sag a bit.
They've been sitting for over 48 hours now and are tough as hell. I'm gonna use a little bit more I think on the surface of the mounts before I put them back in.
Also the contruction adhesive is like an ugly butterscotch color so I'm gonna use some hi temp black paint on em.
