Sure fire! Why not risk your $5K transmission instead of renting the machine and its operator's expertise for an hour?ViruzOne wrote:Im thinking of doing this soon but if i can do the work myself i would be willing to do it, rather than taking it into a shop.
Was all of that necessary? This is the kind of crap that time and time again starts flame wars. Maybe it's sarcasm, but it just doesn't come through that way in writing - so then someone fires an equally smarta$$ comment back and we're off to the races again.maxnix wrote:Sure fire! Why not risk your $5K transmission instead of renting the machine and its operator's expertise for an hour?
Might try sawdust while you are at it!
Like rebuilding a transmission in his spare time? Mechanical fluid exchange is hardly a DIY, as the cost of the machines attest. But then perhaps neither is critical thinking nor analysis?Q451990 wrote: I can't blame him for wanting to save $$ and do something himself.
Heath
He asked a question... Qship answered it - although I'm not sure on the recommendation that '02+ is OK. I can't blame him for wanting to save $$ and do something himself.
Heath
I don't disagree with that part of your statement, but I thought the question was well thought out. Given that ViruzOne posted a link to the procedure - obviously he did some research.maxnix wrote:Mechanical fluid exchange is hardly a DIY, as the cost of the machines attest
Well.... Sawdust is a bit extreme but the point to be taken from this isQ451990 wrote:
Heath
I have noticed at times. I plan on getting my fluid flushed with synthetic also with a BG system. The shifting from 2nd to 3rd is shifting hard. Oddly, two places in my area stated that you don't have to drop the pan and change filter with the BG system. Is this true? I don't think it is because I went ahead and ask for a price with them changing the filter. BTW, where can I purchase the Mobil 1 atf fluid? I know that I need 14qts.bullittandy wrote:
X2
Anybody want to know what the problem with decorum is with this forum? Read Maxnix's answer.
You too are missing my point. What harm was there in asking - especially with some documentation that it's being done successfully on a different brand of car? Do you only get your oil changed at an Infiniti dealership because you don't want to quibble over an oil change? How about wiper inserts? Air filter? How about changing a tail light bulb? Car wash? Air freshner? Somehow, I doubt everything on your cars are done at the dealership given your "plus other junkers around the yard" profile. I don't know many people with junkers that don't like to tinker with them! Hell, if had a big enough yard in a neighborhood that would allow it I would have a few spare parts Q's to play with.RAP wrote:An owner should not quibble at spending $ 125.00 or so to have the transmission flushed if needed?
Thanks for that great answer Tech!! I changed my fluid (regular atf) and filter July 2006. I plan on doing the flush next weekend with synthetic, I think that I'm going to change the filter again for a peace of mind knowing that I will be using synthetic.Q45tech wrote:BG Quick Clean for transmissions will clean the pan if product is used correctly circulating for 15 minutes in HOT ATF, however to clean the pan magnet you must drop the pan. To replace the metal large chunk screen/filter you must drop the pan.
If fluid exchanges are done every 30k or 2 years then you can do a pan drop and filter change every other cycle say 60k and 4 years.
It all depends on how long you want to prolong the transmission replacement.
See, what is really "condescending" here is to perpetuate the myth that someone with only hand tools can effect a "DIY transmission flush" - i.e., a true pressurized mechanical exchange of old fluid with new. If that were possible, the manufacturer's of those machines would quickly cease production because no one would use them. A minimum amount of reflection and anyone can arrive at that deduction. It is not "helpful" to encourage patent absurdities.Q451990 wrote:I just hate to see legitimate questions getting sasrcastic condescending answers. I would like to see a culture of people being helpful here vs. creating an environment where newer members shy away from asking questions and just try stuff that we veterans know won't work, and do damage to their cars! In this case, we have a very specific reason not to try it... toasting the planetaries that will run dry very quickly.
Heath
We're pretty much on the same page here as far as best to worst.maxnix wrote:See, what is really "condescending" here is to perpetuate the myth that someone with only hand tools can effect a "DIY transmission flush" - i.e., a true pressurized mechanical exchange of old fluid with new.
