SniperJoe »
https://forums.nicoclub.com/sniperjoe-u93039.html
Tue Oct 21, 2008 7:46 pm
As far as taking off the tint I just peeled it off & cleaned up the glass.
The brake light just snaps right off ... no screws holding it on. After removal just unplug the wires at the connector which you will see.
The instructions on mine said that you can shrink the film on the back window to contour it prior to the installation.
Somewhere I read that there are several ways to remove the bubbles, one being using some white glue & another way that does not come to mind right now. The bubbles are there because of the factory applied paint on the inside of the glass.
Even though the tint was top quality, my install was not. I was not happy with it because of the small amount of dust & ended up taking off all of the tinting....
I am no stranger to cars & been a modder & hot rodder since high school, but next time I'll have a pro do the install for me. (Keep in mind that I did this myself - alone & outside with no garage. It would be easier & probably have a higher success rate if you had a helper & did this in a garage.)
