DIY: Swapping SR Bell Housing to KA Transmission
blackmagic
Car: 1995 nissan 240sx se w/ rb26dett
go back to the first page and read again. the only thing you need to do to make it work is swap bellhousings...and in my case pull the transmission out again and find the reason **** dont go into gear.
240nicksx
Car: '92 hatch SR20DET '70 McLaren M6GT
great write up! helped me out so much!! thanks hijacker
E7-S14
Car: ess 14 foo!
I did this about a month ago.S14 SR with an 90 s13 transmission.
didn't have to modify anything at all.just swapped all my sensors.
this write up helped me out ALOT.thanks!
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
I just did this last week. Everything went smooth except, I am using a Shaftmasters driveshaft which was not fitting after the swap....I noticed that the area where the dust collar originally was ( KA trans rear half ) happened to be 1/4 inch longer then the SR counterpart and required trimming this was a s13 DOHC transmission. I don't know if this applies to SOHC or S14 transmissions. Everthing is now perfect and has had no issues.
johngriff
Car: 240sx
I didn't read through the whole thread but, to append your write up.
You can do this swap much easier and with MUCH less error if you do NOT separate the rear housing from the dogbox sandwich plate.
You are more likely to drop the shift forks out of place (read some of that in this thread) by taking the rear off. Just leave it on and RTV sealed if you can, by only prying the bellhousing side to the sandwich plate.
This can be done with allot of other trans too! The Z31, S12 trans is shorter, but the sandwhich mount is the same, so you could take a CA20E trans, put an SR bellhousing on it, and drop an SR swap in say a 510 or S12 w/o having to modify the driveshaft.
Lots of interchangeability.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Thanks for the post up John. I was taught that particular way, so I guess it's just natural for me to do it that way. It also lets you get a good inspection of the center bearings and gears as well.
jhott
Car: 1983 datsun 720 king cab 4x4
can anyone help me??? i have a 1983 king cab 4x4 and i need to get the tail housing off my transmission.. i got the pin out that holds my forks....and i took off everything else to try to get it off but it is still stuck on something....?
topless_240
you my man, are a LIFESAVER! same s*** happened to me tonight, ka transmission was spinning freely and fine, then I get the bellhousing on, and tighten bolts and it was freaking stuck, would not shift at all! The clip for the input shaft wouldn't even get all the way on. I'm glad I know this I am going to do this tomorrow
topless_240
need some help, just did this swap and the input shaft still spins freely and smooth, but when I put the shifter on to see if it would go into gear it would not go into any gears, HELP!
johngriff
Car: 240sx
you dropped the shift fork linkages in the rear half. Need to take it apart and redo it.
topless_240
yep I figured it lol, again THANKS for this thread!
jrm5503
Car: 91 Mazda rx7 SR20 DET swapped
Damn i wish i came across this when i blew up 2nd gear at the track. Way more detailed then what i was looking at. Great write up.
frontiersman
Car: '01 Frontier
Will this procedure be the same for using an SR trans for a KA?
Hijacker
'94 F-150
Yep
frontiersman
Car: '01 Frontier
Just one more quickie, do you know if I could I drop a transmission from a 240 in an '01 frontier? Mount wise..
klutch454
Car: 89 S13
Hey guys, nice right up. I just did it, but I'm having some troubles re assembling the tail shaft onto the sandwich plate. I move the selector to the drivers side, to clear and all goes good. But after getting the tail shaft to mate up, and bolt the tail down, I installed the shifter, and it doesnt go into gears right. it feels like it goes into 1st, and 2nd. but wont move to the passenger side, to get to 3rd 4th, and 5th.
Any thoughts? Thanks
