EW »
https://forums.nicoclub.com/ew-u28959.html
Mon May 14, 2007 11:33 am
One thing I like about the Clifford G5 line of product is that they are a complete security line. All but one system has starter and ignition kill. Most alarms just have a normally closed starter kill. All Clifford G5 models have a coded valet switch so a thief can not pop the column, turn on the ignition, press the valet switch, and drive off like you can on 99% of the alarms on the market. Clifford also offers a wireless kill. We normally use them for fuel since the alarm already has a starter and ignition kill. There is no connection from the kill to the alarm. It uses a radio signal to allow the fuel pump to turn on. Disconnect the power from the alarm and you will get no fuel and there aren't any wires to trace down to find the kill. Clifford's BlackJax system is the best anti-carjack system on the market IMO. It works automatically and will literally shut the car down after the carjacker has driven away. Additional sensors offer more protection. Virtually all alarms offer an impact sensor. An impact does not cover glass breakage, a glass sensor does not cover the interior like a prox, none of the above detects jacking or towing. Different sensors detect different events.Back up battery sirens continue to sound even if the siren wires are cut which is the first thing many thieves do after they get in the car. If an alarm, like a paging remote start system from DEI, starts at $699 installed, it is not that hard to add sensors, not bells and whistles to get to $1000. Still, if your car is stolen or broken in to, what are you going to lose even with full coverage? Value of audio, accessories, deductible, etc. No protection or trying to protect a car with a $99 alarm just does not make sense to me. YMMV.
