yozsi wrote:why the hell are you filling through the shifter????? your suposed to fill it trough the fill hole....
tex240 wrote:you wouldnt know how the best way to get at those front 2 bolts for taking the hole top plate off to replace the shifter do you? thanks
I seriously doubt that the oil in there was anything other than the stock oil.. The amount of (Don King- exactly haha) stalagmites (or is it stalagtites? I forget which one comes up from the bottom...) in there must have generated over a LONNG time. Either way I'm glad to have it done now!ricebike wrote:hmm, fiz, i hope that was GL-4 gear oil in the transmission...GL-5 would eat away @ the synchros...hence, the stalagtites/stalagmites on the magnetic drain plug. <mine's look like don king when i did this job @ 105K; changed 'em again @ 150K w/ much less metal on it>
fiznat wrote:Underneath that boot is the most frustrating step of the entire process... and no, I dont have a pic of it cause I got so pissed off... The shifter will still be sticking up out of the hole, and you will see down near the base that there is a little silver ring (more like a C) that is holding it in the hole. The C has little loops on each end of it that you are supposed to grab with a pair of needle nose pliers, squeeze together and lift out. Let me tell you, this is harder than it sounds. The pliers kept slipping out of the ring as I tried to lift it out over and over again-- this took me like 15 minutes to do, just screwing around with the stupid thing. It helps to get one side out first and then "help" it with the flathead.
