tramp_drift240 wrote:that sounds like another variable that'll make my car look like crap when im done.
like, one side pulled more than the other.
If you are going to do it yourself, I actually recommend dropping the strut on both sides before starting & supporting both sides w/ jacks.
One of the things I've noticed when pulling fenders is that the hubs don't sit perfectly even with each other (one side has always been lower than the other - at least in the few cars I've done). One way to check instead of eyeballing is to take a measuring tape out and check from ground -> hub & hub -> top of wheel well.
Another factor that goes into that is the alignment setting - if your toe is off, or camber is different from one side to the other (usually is), that will also affect your pull.
For the most part, it doesn't matter if you aren't pulling a ridiculous amount - and if you look closely at cars with pulled fenders, they aren't usually even on both sides; no one's going to be running back and forth and saying "hey, your flared fender is 5mm diff on this side).
Good luck!
