homeslicej2 wrote:I thought that's what it was, but why? Does it serve as sound deadening too or is it more of a stiffener/rust inhibitor?
Lol sigh Ive told many people this when they asked about bedlinning. It weighs less than sound tar, resulting in you can cover your whole floor pan and still below what a sound tar would weigh= Sound tar from firewall to the rear comes in around 50-90lbs. 1 kit of bedliner is 25lbs. I used more than 1 kit for other cars because of using the roller method and not the spray method used on mine. More durable/stiffer, you wont see rust forming underneath unless its on the other side. Many more great qualities. Search and you will know.
bt2s14 wrote:Wait putting the bedliner down in costly? I plan on doing this to one of my cars..
If you don't make a DIY can you tell us what you used?
BTW: Nice comprehensive write up and nice pics
To some people its costly. I pay around 350 for 2 large kits of bedliner=rattlegaurd from ebay. Thats 4 small kits=2large kits.For the sound tar, I removed the whole interior. Dry ice, hammer, flat head, and chisel. paint wrap and painters tape to cover the areas not being bedlined. bought a couple cans of primer, sand paper, and degreaser (simple green is the best). After I prepped the floor and tapped off the areas. I followed the directions thats given with the bedliner kit. It takes about 20-30minutes to apply (45 min. until it hardens) and settles for touch in a couple hours depending on climate conditions. And about 24 hours before you can start throwing engines, parts, tires, body bags, etc. and you wont even make it twitch .
