I'm told by the Rad. repair shop that the fan keeps spinning (about 10 revolutions) afterthe engine is turned off. He recons that it should only spinn about 3 revolutions and needs replacing. My question is:1. Can it be repaired and if so how?2. Can it be replaced with a better new improved model?3. How are they rated i.e. temp cut in/cut off.
At the moment I have a spare fan and clutch out of a Skyline GTR (bolted straight on) . The clutch out of the Q has a RED spot painted on it and the GTR has a BLUE spot painted on it. I can only guess that this is some sort of Code as to the temp setting.
As the fan blades are cracked I'll be getting a new one, and don't have a problem buying a new clutch.........just wondering if ne1 has carried out a DIY on the clutch and how the thing actualy works?
