DIY: Repair broken Glove Box mechanism.
Pimperish1
Car: 2011 Infiniti M56s
2007 Nissan Pathfinder S 4WD
2018 Nissan Rogue SV
2020 Nissan Rogue SL
I had this happen previously and recently it happened again so I hunkered down. There's a little wheel in the mechanism for the glove box that in my case failed (broke) and I attempted to repair it with epoxy. That held for abut a year then I was back to square one with a glove box that wouldn't open (only one side of the latch would release).
These are the tools I used:
In my case the latch on the right was the one that failed so I had to push it in manually from here to release the glove box:
Once you get the latch to release you can apply GENTLE pressure here...and here..to pop the tabs from the track and move the box forward some more to gain some more needed room:
First rodeo, I attempted to remove the loop at the end of this dampening string from the glove box and broke the string. As you can see I was able to "mend" it, but learn from my mistake and just pop the plastic bit off the side of the glove box(purple circle in bottom photo). MUCH easier to remove and reinstall that way...Go Figure...
Then you can remove the screws holding the inner panel to gain access to the latch mechanism. Remember to be GENTLE, you break the hinges or the box you're looking at around $400+ to replace it (and that's before you throw yourself to the mercy of the dealer).
This is what the latch mechanism looks like once you get it out. The little wheel indicated was the cause of my repeated grief.
That wheel has two pins that fit in the notches (orange) and "cam" when you pull the handle which pulls both latches inward to release the box. One of my pins broke (blue) so one latch was immobile. Apparently the wheel looses lubrication and can't handle the resulting added stress. As you can see not much [useful] lube there.
I ordered a replacement latch from Ebay for $30, it was off an M37 with a tan interior. Unless your pull handle is broken the color doesn't matter. All the inside bits are the same. You use a small flat head screwdriver or something with an edge and you basically GENTLY pry the wheel out. I didn't need to take the handle apart to fix mine but if you need to, just tap the silver hinge pin out and it all comes apart rather easily. DON'T LOOSE STUFF!
I gobbed a healthy dose of white grease into the area where the wheel sits and was sure to get some into the notches. Lined the pins on the new wheel with the notches at 12 and 6 and snapped it into place. Once everything is clean, assembled and ready to get back to work install it back into the guides...I recommend situating the right (longer) latch first (green), found that to be easier:
Once you get that in, you can push the two latches in towards the center to get the other in it's guide and seat the mechanism, there are two guide pins (orange):
Hard part's done (unless you broke something), so put her back together (without breaking anything) and give yourself a pat on the back. You just saved yourself over $500 bucks. Whole process should take about an hour (actually less, but seriously, you don't want to break any of this sh*t).
Reason: Revise Title
Ilya
Good work!
Malbec 56 Beast
Car: 2013 Infiniti M66xS Totaled 4/11/20
What's next???
2010 Subaru Legacy
1983 Porsche 928 S Euro (Sold) 2/17/20
Just had this happen to me
Ordered a new mech from the dealer and it comes with both arms.
I had difficulty in removing the lock so I went to a friends shop and he broke it apart to remove it, note if you do this make sure you do it slow sure to the lock coming apart.
Put it all together and works like a champ.
Andy
Pimperish1
How much did the dealer charge for just the lock mechanism?
biggie
Happened to me a while ago, found a used glove box from junkyard online and had it shipped to me. Was a different color, so just swapped the mechanism.
drtbar
Same thing happened to me a week ago and I just ordered a whole new glove box without finding this thread. I swapped the glove boxes and was content to not be able to lock the glove box until I found this thread!! Swapped the handle/lock mechanism and I'm back in business. Thank you so much for this write up!!
GMBQ70
Car: 2015 Infiniti Q70 3.7 AWD
Nice work! Well done.
jmissile
Car: 2011 m56s
Does anyone know the secret on how to remove the lock mechanism from the latch in order to transfer to a new latch mechanism?
jmissile
Car: 2011 m56s
Update: there is no way to remove it without carefully cutting it out of the latch. Used a Dremel on it for a few minutes but got it free and then slid it right into the new latch and it locked right into place
Big_Tone
Car: 2011 Infiniti M56x (White w Java interior; Tech Pkg)
PPE Headers; HPS Intake
Custom 2 1/4” exhaust with Jones Exhaust X-Pipe
Infiniti Sport mufflers
I'm having this issue now. Is there a way to repair the links so the images can show?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Big_Tone wrote:
Sat Oct 26, 2024 5:27 pm
Images are there for me. I'm using Firefox on a laptop. You might want to try using a different web browser.
Ilya
Can confirm they are showing on Chrome as well (on PC).
Big_Tone
Showing for me. It's only taken me 3 months to confirm lol. I changed from Edge to Safari. I still haven't done anything about my glove box. Going to order the mechanism this week and tackle it over the next week or so.
