DIY: Rebuilding an SR20DET
Slipstream
Car: '94 Sonoma, '90 300zx n/a
Hijacker: Would you be willing to rent out your valve height measuring tool?
Hijacker
Car: '92 240sx Convertible
'94 F-150
I don't actually have one... I did the cheap way and just matched the shims to the rocker guides. It's not correct, but its better than the old method of just putting random shims in
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Hey Bartmeister. With the head, upper and lower oil pans, and front cover bolts removed is there anything else holding the front timing chain cover on? According to your guide and the FSM there shouldn't but it won't seem to budge even after a firm mallet smack.
Hijacker
'94 F-150
There shouldn't be anything holding it on at that point. It's probably the oil pump spacer getting jammed on it funny like. Try taking two small screwdrivers and using them to seperate the front cover from the block and then walk it off. I like to use them to pry near the guide pins as they can sometimes make it difficult to remove as well.
Of course, double check that all the bolts are off. I've forgotten to remove one in the past and nearly snapped the front cover in 2.
redtop91
All the bolts are off. I tried your suggestion to no avail. The upper part is loose but something seems to be holding the lower half on. I'll triple check everything I guess.
EDIT: Upon a second examination, I found that as usual I fail at life. Note to self and others tap the front cover away from you if you are looking at the inside of the cover and it'll slide right off. Should been obvious since the sprocketed portion of the crank runs through the front cover preventing up and down motion. Durr.
Modified by redtop91 at 7:42 PM 10/3/2008
Sil80315
Car: 1991 Nissan 240sx
wow good write up. im in the process of rebuilding one of my sr's after it god a rod know so im replacing the main and rod bearings..now the only question is on the bearings where they have alittle tab on them..do both sides of the bearings tabs touch eachother or is it oppisite sides from eachother?
Hijacker
'94 F-150
Notches go on the same side as each other.
I prefer to match my rods and caps up via the numbers stamped on the side. Nissan always stamps the rods the same, so it's a reliable way of doing it. So if you're rod is for Cylinder 1, make sure the '1' on the rod and cap are on the same side.
jr_ss
Car: 95' S14
Is the oil pickup still attached? If so that's your problem. I did the same thing when I was redoing the timing chain/guides on my engine. I couldn't figure out what the hell was still hold it on.
iceman.chris
Car: '90 S13 Hatch - SR20 (sold)
'95 240sx LE (dd)
What about if you want to use ACL race main + rod bearings, how do you select the grades for those? Is it just "standard" for any of the OEM grades 0-6?
s13-t
Car: s13 pig nose w/blacktop sr20det
hey hijacker
getting ready to send my block out to the machine shop. but I was told I should remove the plugs on the block first. One is under the front cover. two are on the exhaust side near the oil return for the turbo. and the fourth is on the left side. they are allen heads... I was wondering if you know what size they are and whether or not I actually need to remove them for the hot tank.
Hijacker
'94 F-150
I let my machine shop pop them out and replace them.
Kalypso
this thread is still my all time nico favorite.
EfiniRX7
Car: 93 FD3S not going anywhere, 2003 E46 M3 traded, s14 sold, 2010 camaro sold, now another kouki s14, FD did go somewhere, Now a 535whp rotary Kouki s14
This will be use-full in a few days. Im replacing my head gasket and having the head milled(if it needs it) along with being hot tanked. After reading about shimming the head and such it got me worried. Can I just put everything back in the spot it came from, and be all right? I don't have any gauge or dial tools for measuring nor do I really understand what Im doing. Im a rotary guy being forced to work on these piston contraptions due to low funds. Thanks for the info.
lifewater
Car: 1990 S13, 1996 S14
Awesome guide... I'll be using this come time for my build!
I have a quick question. I blew my motor and damaged the block. Luckily there was a block for sale close by so now I have something clean to work with.
I will be using my undamaged crank from my blown motor in the new block. Are bearing choices still as simple as the addition stated in the guide if your mix-matching cranks/blocks? Or do I have to take anything else into account?
s13-t
the baffle next to the mains on my block broke... where can i get a new one? and how do you get the pressed in tubes out of the block before machining?
Thank god nissan stamps the rods and caps with the cyl number otherwise I would have been screwd....
Modified by s13-t at 2:02 AM 10/16/2009
Stripes
Car: hatch, coupe
Question.When boring .020 over, is it necessary to resleeve the cylinders or is it fine to just bore the stock sleeves?Also this may have been answered already, but when using aftermarket pistons and rods is it necessary to have the crank balanced?
One more thing. I noticed when looking at aftermarket bearings such as ACL and Clevite the whole set comes in the same sizes. With the clevites ( http://www.enjukuracing.com/cl....html ), it states they are all standard size. Is this okay or does each pair need to be special ordered to the right size?
Modified by Stripes at 12:49 PM 10/16/2009
duffman1278
Car: 89 240sx Hatch, the wildcats!
You're fine if you just use ACL or Clevite's one size.
Boring .020 seems like a lot. Have a shop check out the condition of the cylinder walls to see if you even have to go that far. They'll be able to tell you if you'll need sleeves or if you can go less.
s13-t
bump!!!need helpplz answer my question above
duffman1278
The pressed in sleeves will get pulled out by the machine shop. Let them worry about that, as well as putting them back.
As for the "baffle next your main?" I'm not exactly sure what part you're talking about here so I can't help you out much. For some reason I'm thinking that you meant the oil jets that are in each cylinder?
s13-t
this baffle...
duffman1278
Call up West Covina Nissan.
http://www.thenismoshop.com/
They can get JDM parts for the SR. I dunno if it's an SR part only but you could have them check. It would be best though if you searched the part number on FAST then gave it to them so they get the exact number. Or email them with that pic tell them you want the baffle.
s13-t
Thanks, I really appreciate the help. I am emailing them right now.Hijacker I hope its cool for me to send them that picture.
Asia989
Car: 90 s13.4
can i use moly lube as assembly lube? when putting the crank in??
duffman1278
Yes. Moly lube will work just fine. I did that on my integra when I rebuilt it and never had an issue.
Asia989
Car: 90 s13.4
now to figure out how to do poor mans ring gap to oem rings...
duffman1278
OEM piston rings usually are pre gapped. However check now and assure yourself of it.
To check the gapping just insert the rings into the cyclinder and line it up as best as you can with a piston. Then with a feeler gauge, find the gap between the ring and verify it's with in specifications.
Asia989
Car: 90 s13.4
What would be stock gap? my feeler gauge im using as two numbers on it .021.023
duffman1278
Your feeler gauge only has .021 and .023?? You need to get yourself a feeler gauge with way more gauges than 2 lol! Check the FSM for the gapping.
Asia989
Car: 90 s13.4
duffman1278 wrote:Your feeler gauge only has .021 and .023?? You need to get yourself a feeler gauge with way more gauges than 2 lol! Check the FSM for the gapping.
lol, my other one says .012, a guy from rs enthalpy said they should be dead on or close
duffman1278
For the most part, yes they are pretty close to dead on. However a set usually has an array of different gauges from like .05"-.23" you need to get yourself a proper set so you can properly measure the gap.
