DIY radiator reservoir
tetsuo
Something about these things.. they crack and I know there's people who are in need of a replacement!
All you need is any type of a drink bottle, and that red chilli sauce that the Asians (esp southeast Asians) love, I think it's spelled Sriacha sauce? Well it has the peacock on it so if you see that you're good. They have em at any Asian market, guaranteed.
It has a squirt thing on the top... and if you pop the tip off of it you get your nice little nipple for the hose. I just put two wire ties and it doesn't leak. You're almost guaranteed with a metal harness.
NCturbo75
Car: 2006 INFINITI M35...
tetsuo wrote:All you need is any type of a drink bottle, and that red chilli sauce that the Asians (esp southeast Asians) love, I think it's spelled Sriacha sauce? Well it has the peacock on it so if you see that you're good. They have em at any Asian market, guaranteed.
hey...those sauces are great...in a bowl of PHO`
by the way....its a rooster not a peacock.
Tech12
Car: 91 240sx Super Hicas
Thats pretty much amazing. IS there any worry of pressure if your "res" doesn't have a breather hole/tube/whatever?
ArcherV20
Car: 1995 240SX
Haha! You sir are my hero.
Fenvy
Car: 2005 350Z Base 6MT
you need the hole or water flow is not so good
try sucking with your might on a 12oz coke bottle and you will know what I mean, the negative pressure will prevent most of the water from being sucked back into the radiator, or positive pressure going into the bottle.
I say mount it nicely, straight up vertically and bore a little hole.
if you want to do better, get those 1/8 in clear hoses, bore a little hole and then glue that thing into the hole, run the line toward the floor and zip tie it down
480sx
Car: 1996 Pearl White 240sx
Boil your car over and see how well your catch can works lmao.
mchkc240
Car: 91,92 Nissan S13 - SOLD
98 BMW E36 - Running
That's sick! I was just doing overflow tank research because I need to get one. May be I should DIY my own! LOL
WhiteSilvia
Car: 1996 Nissan 240sx
I use a Gatorade bottle for mine, have been since I got the car and the resivoir was cracked open
And yes, you need an opening in the top of that, and it'll have to sit upright, not upside down.
mchkc240
WhiteSilvia wrote:I use a Gatorade bottle for mine, have been since I got the car and the resivoir was cracked open
Haha that's really ghetto~ Why dont you get a replacement from junkyard?
WhiteSilvia
Because no junkyard has a replacement. It's something that Nissan went really cheap on. They crack VERY easily after 4-5 years. When I bought my car it had a small crack on the top, I simply touched it and it created a sweet cartoon effect causing several more cracks and pieces of plastic falling off into the coolant
The Gatorade bottle uses surprisingly strong plastic, and I have it secured tightly in the engine bay sitting upright where the original coolant resivoir sat. Works great
mchkc240
WhiteSilvia wrote:Because no junkyard has a replacement. It's something that Nissan went really cheap on. They crack VERY easily after 4-5 years. When I bought my car it had a small crack on the top, I simply touched it and it created a sweet cartoon effect causing several more cracks and pieces of plastic falling off into the coolant
Here's the interesting part. If you go to dealer they are gonna charge you 90 bucks for that P.O.S plastic. Pay 10 more bucks you can get a full aluminum one.
mchkc240
tetsuo wrote:
Oh also I think you will need a zip tie for the bottle. Because It will move around when you are making turns
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
WhiteSilvia wrote:It's something that Nissan went really cheap on.
Not really, it's just too close to the battery.
