nuQ »
https://forums.nicoclub.com/nuq-u4532.html
Wed Mar 19, 2003 4:28 pm
one more thing. if not able to pull the coolent plugs on the block, and sure that only distilled water is in the system, do you just measure the amount of water drained, then replace with coolent according to the total amount of coolent/water in the system(10.8 quarts if i remember)??? also,,,,according to the manual, must go through some steps on the temp. manual on dash to open the heater door???? on most cars, only have to run the heater on high. anyone know about this. want to flush the whole system, obviously. something like press temp. up three times, then fan 2 times........ jeff
