meet07 wrote:Yea I know the phrase "the bigger the better" doesn't always mean its the best but for turbo it helps usually. when I talked to the guy at the machine shop about opening up the part around the valves he said that it would lower compression. I told him was turbo and he was like "oh". I want as much air going into the turbo as possible :-)
Your talking about unshrouding the valve? This will lower the comp, but unless you remove a lot it wont make much of a difference. Just make sure you place the new head gasket on the head lined up like it will be when its bolted down, and mark around the gasket. You do this to make sure you dont over do it and have a part of the gasket sticking nto the compustion chamber. That would not be good at all.
Also if you port the throught make sure you port the whole port alittle. Like if the throught flows 180cc and the neck flows 200cc and the mouth flows 240cc. Lets say you make the throught (closeest part to the valves) flow 195cc, but dont do anything to the rest you wont see much if any gain as the neck still cant flow more then 200cc and the mouth will still only flow 240cc. You have to port evenly, what you do to one area should be done to the rest. Just becarefull not to mess up the Short side turn, you can lose a lot of power messing this up. If you have or know of a flowbench that will be your best tool in porting. Put it on before then every so often to see what is changing and if your helping it or not.
One more thing, if your porting then do a valve job too. At least a 3 angle. This will pull it all together.
You got my number still?
