~DIY mods for 240SX?~
Silvia_Freak
Car: 1992 NIssan 240Sx KA24DE
Hey guys. I was just surfing the net the other day look at some DIY mods for some other cars out there. I was just wondering and tried to search; for some DIY websites for NISSAN 240'S. If you guys can post up websites dedicated to the 240's that would be much apriciated. FOr (DIY) I was trying to figure out how to make your own COLD AIR INTAKE. Thanks agian- Silvia FREAK
SmithSR
Car: 240sx
Read the articles section here on NICO and find the 240sx.org FAQ. Good starting point.
240marcuSX
Car: E34 525i
E46 M3
imo the best thing you can do for free is take out stuff that you dont need, if you do a home depot intake, youre just going to replace it later when you realize how ghetto it is. save up for good parts, but dont over-pay to get bling.
Axel Grungy
Car: 2001 G20 5spd
take out your back seat, who needs it anyway
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
You can advance your timing if you feel like running premium.
You can...uh...do something or other to your stock airbox. I don't recall what the mod is, search for it. I just bought an intake.
You can take stuff out (back seat, other interior, blah blah blah).
You can adjust tire pressure. This makes a pretty big handling difference, actually.
Can we adjust camber with stock equipment? I know I could on my WRX. I haven't really looked at it on the S14 just yet.
I think that a sleepy eye mod is either cheap or free. I have a Kouki S14, so I dunno how the hell you do it.
I did lots of tiny interior stuff for cheap or free, like the following:
-Creatively mounted Air Spencer air freshener
-Change color of interior lighting (mine's blue)
-I didn't like my ghetto-looking Nissan OEM faux-wood dash trim, so I pulled it off with my bare hands, then cleaned the dash, so it all looks nice n clean now.
You can paint wheels, valve cover, or brake calipers, if you're just antsy for something to do. My car is Silver Moss, so I think I'm going to get the valve cover painted to match (not exactly DIY though). Might just do it black myself.
You can paint emblems/markings black, or whatever other color you want.
I've heard about "smoking" S14 tail lights. I have no idea how this is done, but I know it looks super cool.
Bruno240
man i could of tinted my taillights, i had extra window tint and replaced my tail lights. I wonder why i never thought about putting the two together.
i wonder what it owuld of looked like on my black car
Graphfixz
Car: Black 91 240SX Hatch
WoW! with your bare hands?
j/k
bentsprocket
I found this in my old stuff laying around
Tinted Lenses
Remove the part you want to tint.
Using the 600 grit sandpaper, carefully wet sand to remove the letters stamped into the lens (they usually indicate DOT certification, part number, etc.).
Wet sand the entire part with the 1000 and 1500 grit sandpaper until you get a nice, smooth result.
Clean the part with alcohol, and place it where you intend to paint it. Try not to touch the surfaces to be painted, as you risk leaving an oily film behind.
Apply the spray tint in broad, even strokes. Do not stop half way across the part, or else you will end up with an uneven and blotchy result. You want to coat the entire surface in one light coat, if possible.
Continue coating the part with light coats of the tint until you achieve the desired darkness. It may be wise to tint the part, leave it to dry for a few hours, and then test it on the vehicle to ensure that its not *too* dark.
If you find that the part is too dark, you can use 1000 grit paper to sand off some of the tint spray, however, use extreme caution, because uneven sanding will result in "bright spots" in the lens when illuminated.
When you are satisfied with the results, allow the lens to dry overnight.
After drying overnight, lightly wet sand the part with 1500 grit sandpaper, and apply a thick coat of clear coat. This will give the part the gloss it had before, and make it look more smooth and even (the tint tends to appear blotchy).
Allow the clear coated part to dry for several hours. If you find the clearcoat is not perfect, you can wetsand it with 1500 grit sandpaper, followed by 3M Hand Glaze to restore its shine. Generally, however, this will be unnecessary.BTW EBay has "spray tint", in ebay search
Modified by bentsprocket at 10:13 PM 3/31/2005
Modified by bentsprocket at 10:14 PM 3/31/2005
bentsprocket
Here is a way found this through google......
Custom Badge Overlays
Purchase some quality vinyl. Often your local sign shop will have odds and ends that they will sell cheap/give away.
Using masking tape, attach a piece of paper over the emblem you wish to create an overlay for and rub the area with a charcoal pencil.
Cut out the outline of the badge with a sharp hobby knife.
Test fit the new decal to ensure it fits perfectly over the badge.
Tape the newly created stencil to the vinyl and cut out as many overlays as you require.
Remove the backing and carefully install your new overlay. Don't rub it down until you have it placed where you want it, as some trimming may be required to make the edges smooth.
When the decal is perfectly placed, rub it down good and do the next one.
w1ngzer0
Car: Pfft. i don't own a box
if you know welding you can DIY engine parts
Bruno240
I just did the DIY sleepy eyes and it took me about a half hour and it looks great. I cut that brown wire and the used a toggle switch for the blue and silver in the kick panel one and now i have sleepy eyes!
StrangeLove
Car: 1995 Nissan 240sx
The stock intake mod is:
The black box that your air filter sits in, remove the bottom half, and secure the airfilter to the top half. Makes your car sound MEAN. Oh, and its free
HashiriyaS14
'08 Honda Accord
'08 Honda NPS50
'60 Honda Super Cub
Graphfixz wrote:WoW! with your bare hands? j/k
You mock me, but try it sometime. It effin' HURTS. I didn't want to use a screwdriver or anything because I didn't want to scratch the plastic underneath, but it's HARD to get that stuff off. I pulled a fingernail half off doing it.
Graphfixz
pills wrote:The stock intake mod is:
is this the same mod found on the FAQs?
about taking off the 'Y' looking thing... umm.. yea?
Stev0n
Car: 90 LS13.5 M6
08 HD Superglide 106ci M6
94 Ranger
97 mercury sable
96 Rape Van
has someone already posted the sleepy eye DIY thing here before??? I don't feel like searching for it if it's not there «— lazy me...
yessir240
Car: s14 zenki
wait what exactly do you do for this intake mod
