hek1620 »
https://forums.nicoclub.com/hek1620-u30936.html
Sat Aug 20, 2005 4:33 am
damn, u guys seem to be going on major missions. i wanted to have "sleepy eyes", but i also wanted to have a set of rectangular yellow fog lights. 2 reasons, i like way yellow fogs look, and i know that pointing the light down makes all the light go into the bumper instead of out on the road. unless u make some bracket or something. so, all i did was replace the stock light with sylvania's. the ones that are supposed to be the closest thing to h.i.d.s. disconnected the motors but left them attached so they don't get dirty, then rolled them up to my dsiered position. onto the fogs. now, to drill the holes where i did ur gonaa need a pretty powerful drill. the third and last one i used was an 18 volt, 2.4 amp drill. pop ur hood. if u look down behind the bumper u should see an edge that sticks out of the bumper towards the the car an inch or two. grab ur fog light, sit in front of the car and now that u know where this flat piece of matal is place ur fog light under it and see where u want it. mark it from the top and drill. make sure u use a big enough metal bit. this will take a couple of minutes, cuz its pretty thick. wire up ur fog lights to each other and pass one through behind the splitter and mount that ****. mount the other. now take out one of ur front turn signals. i used the passenger side. connect the positive to the BLUE and GREEN wire. and the black to the black. wrap them tight. turn the lights on to the first position(parking lights). if ur fogs turn on, ur the man. turn them off, put turn sugnal back in. then pull the wires in behind the bumper so they don't hand all over the place. tie them up with zip tie and stick into one of the holes in the back of the bumper. if they don't(turn on) u suck. and i don't know what to tell u. i'l post some pics later when its not 1,000 degrees outside.
