carps13guy »
https://forums.nicoclub.com/carps13guy-u99155.html
Wed Jan 14, 2009 11:54 am
ok, i know ive seen a DIY thread somewhere but could not find one when i searched. so i have been looking at my 240's front end and hate the way the bottom of the bumper was executed. the bumper just ends and then jets in like six inches and there is a little lip at the bottom. i had seen a 240 with the home depot lip the other day, but he had the molding flush with the bumper, covering up the ugly part. i knew that is what i wanted to do.
MATERIALS:-1x4 piece of wood, i used a 10' piece and cut it in half in case i had to re-do it.-base board molding -5/8" self drilling screws-can of black paint-2-4 bolts and nuts to mount the wood to the bumper
TOOLS:-jig saw with wood blade-screwdriver-drill and drill bits-sharpie
ok so first off get some cardboard to get the shape of the corners of the bumper.
then cut a piece of wood to the length of the mouth with an inch or 2 of excess so that you can screw it to the wood corner pieces. heres what it looks like when the corners were bolted to the car, and the middle piece was screwed the the corner pieces. notice that it is painted black to make it less visible
i took the molding and cut an inch of height so that it would be 3" instead of 4". then i took the paper off of the back and applied it to the wood so that i could start screwing the molding to the wood support.
i drilled holes three inches apart from each other on the sides and in the front. but not in the middle. to support the lip in the middle i bought some inexpensive pieces of angle supports from the hardware store and mounted it to the wood behind the lip. i do not have any pics of this, but trust me you'll need em, or the lip will sag in the middle and not look very attractive. then i cut an inch of the molding where the mouth is to open it up a little bit. oh yeah, save the excess that you cut from the molding. i used a couple of pieces to hide the wood on the inside of the mouth.
the last thing i did was borrow a black paint pen and cover the shiny screws to make them less notable. i think it turned out pretty damn good for my first try. and for 25 bucks in materials (which is enough to make two) its not a bad bargain either.
thanks for reading.
Modified by carps13guy at 5:38 PM 1/14/2009
Modified by carps13guy at 1:53 PM 1/15/2009
Modified by carps13guy at 5:30 PM 1/19/2009
