DIY key your new silvia trunk lock to your key!!!!
Armstec_S13
Car: S13 Coupe
ok im gonna try to make this write up, here goes, everyone of you that bought a silvia trunk lock know it's a ***** to get it re-keyed and jerks wanna charge an arm and a leg, i didn't want to pay crap so i did it myself, and i decided to make this write up for all the 240sx/slivia S13 homies, hope you guys like it....
it only takes about 20 minutes max!
first you need your existing trunk lock off your car, then your silvia trunk lock,
tools1. a small flathead screwdriver2. your original lock cylinder from you trunk
i already did this on my car, first get youe original trunk lock and look at it should look like this ......
first thing you want to do is take off the silver cover off of the front of the lock cylinder, i used small screw driver to lift the edge on the back thats holding it on the lock cylinder like this.....
sorry for the blurry pic but you get the idea, but it should look like this.....
next, remember what way is up, the little bar should be like the first picture i used here, take your small screwdriver and pull the round retainer off so you can take the small spring off like so....
should look like this now...
now that you've taken that off you can remove the spring thats on there like this....
from here you can see the 8 key pins now really remember whic way is up it should be like this
next you can pull out the actual cylinder from the silvia casing, here you can do two things, use your existing cylinder and replace it with the silvia trunk lock cylinder (skip to silvia trunk lock cylinder removal below) or re-pin the silvia trunk lock like i had too, 1 pin at a time, you are also gonna have to pull the lock cylinder out of the silvia trunk lock too (either way) the same way we removed the cylinder from the old casing but on the silvia there is a plastic cover/retainer you have to remove on front, looks like this....
to remove that just carefully push the four little tabs on back to pop it out, .....
i didn't want to take the cylinder since i've already done mine but you get the idea
from here you can replace the key pins, what you do is pull one pin from the silvia cylinder and replace it with the one on yours, it has to be in the exact spot you removed the other pin from the silvia cylinder, remember what side was up like i said in th begining, it's the same on both the silvia lock and the USDM one.
there is a spring in each of the key pins carefull not to lose them just keep them in there.
make sure you push the pins in all the way so they can lock in place
if you decided to use your cylinder instead of replacing the pins forget most of the last pictures, well by this time it should be done, now all you have to do is put everything back the same way you took it apart, install the lock on your car and BAM!!!!!! you've got a jdm silvia trunk lock that uses your orginal key instead of paying an arm and a leg to do, no more having to use two keys or replacing all your locks or re keying the whole F-ing car.hey if you live in the east bay i can do it for you for $10, just let me know, remember, you have to have your original lock cylinder along with the silvia cylinder for this swap.
feel free to ask any questions, im always online so i can answer within a few minutes sometime, thanks for reading and hope you guys liked it, had to share this with all the S13 homies out there!!
well here is the final product.....
Modified by Armstec_S13 at 9:25 PM 2/17/2008
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
good write up man! r6_240sx or adrian_s13, please STICKY THIS!!
btw, i live in fairfield. lets meet up sometime?
Chris28
Car: 92 s13 KA-T
Nice write up! Haha my coupe is the parts car, so I won't be needing this, but it's good to see someone figuring something out on their own rather than just paying someone to do it. Nice car too, looks clean (the back at least)
Armstec_S13
Car: S13 Coupe
thanks man i can put more pics if you guys want to see the rest of the car
pflicht
Car: 1991 Nissan 240sx - SOLD
2000 Lincoln LS - DEAD
1997 Nissan Maxima - DD
1991 Nissan 240sx - Project
Very nice write up!
Armstec_S13
Car: S13 Coupe
cool man sounds good, i lived there now in vallejo
thanks, i got my trunck lock last thursday and installed it in 20 minutes, before i got the lock i saw that no one had a write up so after i did my lock i figured other people needed to know, this is the first time i've messed with any kind of locks so i was happy i did it in 20 minutes installed
hey! i know ya! you did the alternator on my car last year....lol
574-240sx
Car: Nissans, Toyotas, Subaru
Great write up I was going to have a locksmith do this for me when I got some time.
dickie
Car: Killer Turtle
JESUS CHRIST! sooooo many consecutive posts in one thread... Next time you want to post responses to more than one person, use one post to do it. You can use the edit button to add information to an older post.
I'm going to clean this up then article-ize this for you, Armstec. What do you want your custom title to be?
Armstec_S13
Car: S13 Coupe
sorry, article-ize? really? thanks umm oh custom title?
cool, thanks that is real awesome , wow, i've been thinking but i have no idea what to have my custom title how about "cool jdmness" i dunno lol,
Modified by Armstec_S13 at 4:17 PM 2/18/2008
dickie
Car: Killer Turtle
we have a special section for articles our users submit, but to be put in that section they must be formatted and polished. hence the term article-ize.
for submitting the article to be used as such, you receive a "custom title" under your user name that distinguishes you as a contributor opposed to a regular member.
it can say whatever you want limited only to space and appropriate language.
jdm_master_X
oh snap yea! how have you been bro? get an SR yet? hahaha
Armstec_S13
Car: S13 Coupe
good man, you? naw i ran into some stuff, so i spent my money, then i needed a clucth i got a cheapo xtd now i think that thing is goin out, i don't even mess around to mess up my clutch
Armstec_S13
Car: S13 Coupe
how will i know when it's articalized? where would i find it? for my custom title i do want "cool jdmness"
Well-done!
Great writeup, man!!! I'm gonna do this next weekend, I've been relying on the trunk release all along!
dickie
Car: Killer Turtle
Armstec_S13 wrote:how will i know when it's articalized? where would i find it? for my custom title i do want "cool jdmness"
check out 240sxtech.com under the exterior mods periodically, I would assume it will be moved there very soon since its formatted and ready to go. Enjoy your title, and thanks again!
Armstec_S13
Car: S13 Coupe
thanks, yeah i didn't want to do that and im sure no one else will after this write up, sad that locksmith charge so much to do this, let me know how it goes or if you have any questions just ask and i will answer them for ya!
Duce40sx
I just did it!!!!!!!!!!!!!!!
15 Minutes! I changed the entire pin cylinder. You don't even need to remove the Spring. The entire pin cylinder slides out.
Great Write up.
HEY AZhitman, add this to the TECH page.
dickie
Car: Killer Turtle
yeah, add it to the tech page!
m tr4nch
Car: RS13, Z31, P11
awesome write up man, ive been wondering about this for a while like i said in the other post. now i know how to do it. thanks!
