offroadbob »
https://forums.nicoclub.com/offroadbob-u58573.html
Sat Mar 15, 2008 5:51 pm
{SPARK PLUG WRITE UP}
First off get your spark plug. I chose to use some spare Bosh platinum spark plugs I had laying around.
Next you need to break off the electrode ground.
After you have it broken off it should look like this (I just used a pair of pliers)
Once the ground is gone you need to break out the electrode in the center of the plug.
After it is broken it should just come out like this.
Your plug should look like this (after a quick cleaning)
Next you need to work on the key. You need to grind it to 3/8" wide (the width of the shaft of the key). Then grind the top of the key so that it measures from the groves in the key 5/8" (give or take depending on how far it goes into the plug.
now it is time to move onto the installation. Get your glue (I used the loctite but epoxy will work great too). ~sorry about the blurry photo but you get the idea~
I used a thread bobbin to hold the spark plug upright.
Then add the glue to the hole. Fill it to the top!
Wait for it to dry (most cases 24 hours) Now enjoy you new HP gains!!!
Sorry about the dirty car... it seems every time I clean it the dust attacks it the next day.
