DIY: Intake manifold mysteries revealed! Emissions removal
fiznat
Car: Grown up :(
No problem, thats not a stupid question. The hose on the valve cover that you are talking about is only PART of the PCV system. The entire system, which is designed to evacuate gasses and blowby from the crankcase and head, includes a valve and some piping located down underneath the intake manifold.
240sxdriftdaily
Ok, I began my intake manifold project today. But I didnt get too far.I first removed intake pipe, radiator hose, fuel rail and such.Then proceded to remove every bolt that looks like it would hold the mani to the block in total about 8 12mm nuts and bolts, and 3 14mm used on a bracket.From Fiz's pics it looks like there is another 2 bolt bracket but I donot see it.I know Im close cuz the mani is loose and can move it a 1/4" off the block.
I cant get the upper manifold off Ither, and Ive removed all the bolts I can see.
Do i just need to look harder, or can you guys give me some tips on removing my manifold.
Yes, I have searched, but If some one has any applicable links please let me know.
I feel like such a noub.Thanks
fiznat
Car: Grown up :(
Yup youre right, there are two support brackets that hold the intake manifold to the block, one has 3 bolts and the other has 2. The one with 2 bolts is much thinner (its like a rod) than the 3 bolt one, and it is located to the far right (front) of the manifold as you are looking at it.
Taking off the intake manifold is one of the more pain in the a$$ jobs on the 240sx haha, so dont feel like too much of a noob-- everyone has trouble with this one.
SlIp'n'sLiDe
Car: 240
to tell u the truth, ur better off taking brackets off of the block, because it was way easier,hint. there is 1 bolt between the alternator and the block which is a ***** to get at but it can be done with a 14 mm wrench. use the closed end and go at it from the front of the car and get some good leverage on that guy cuz its on there....after thatsoff, then take off the other one which is like 2 runners back..lol.well hope this hepled u in someway, cuz as of right not, my intake mani is off, and i just got done sanding it and polishing it.
SlIp'n'sLiDe
Car: 240
question for fiz, there are butterfly looking valves right before the cylinder head, what are those, cuz i noticed that they are connected to the back of the upper portion of the intake mani,idk what that is, or what to do with them, and i cant figure out which line goes to them and im about to loose it!!!!!!help please
fiznat
Car: Grown up :(
Those are the secondary butterflies. I didnt mention those either because some people remove them and some dont. There are a couple things you can do:
1. Leave the rod in (take off the valve that the rod is connected to on the back of the manifold), but remove the butterflies off of the rod (there are small screws holding each one on)
2. Pull the whole thing out (you dont need them at all, but remember to plug up the hole that the rod went in on the back of the manifold otherwise you will have a huge vaccum leak. A threaded in bolt, or a bolt with loc-tite works nicely.
SlIp'n'sLiDe
Car: 240
thanks fiz, i really am now happy that i know what those valves are, so i counted now after a took off my erg and pair valve, i have 1 running little line, and thats for my fuel, it that right ? or should i have more than that?>>??
240sxdriftdaily
OK, I finally removed the mani and got it cleaned and painted.But I am still confuzed about the the vacume lines I want to route them the cleanest/practical way possible. I mostly had it figured out ; relocate pcv valve to a more accesible loacation and run it to a catch can and run that to where the Charcoal canister was connected. Also planed to run valve cover hose to same catchcan, but I'm not sure if it needs to see vacume before Throttle body?(like stock)
I'm futher confused becuse in the future i place on going turbo, So wont boost puressurize the mani and all vac lines?I assume the Pcv might be ok since it has a check valve the would prevent it seeing boost.
So then I though wouldnt it be possible to use Pcv-like chech valve on all the vac lines to a single source of Vacume from the mani.? But my question is would there be a problem when boosting because all Vac lines would be closed by my checkvavle.
Or If and when I do go turbo would i need to relocate all vac lines to a single source of vacume from the intake side of compressor?
Is there a difference between Vac before and after Throttle body? What needs to see what?
Also What cap/plugs does everyone use to block off lines i.e. PCV runners ect.?
Thanks, I know its a tall order of Q's (but I have more where that came from )Gus
pr240sx
There is also a small screw hole between runners 2 & 3 that secures the rod in place.
As for removal of the manifold, its easier to remove the starter,alternator and both support brackets.If you have removed all the bolts, manifold moves out couple of inches but you can clear the head studs, remove the brackets.
As for plugs, vaccum plugs plus silicone. I spread some silicone on the fitting then slide the plug in.
240sxdriftdaily
O yeah thanks I made sure to put that little SBValve screw back in and sealed it with rtv.Yeah those brackets a PITA to loosen without at least removing alternator.Well ive never seen vacuume plugs, I assume Autozone has'em.?
here is a pic of the vacuume sensors the are on the back of the block, since they arent mentioned I assume they are not necceary.http://us.f1.yahoofs.com/users/670e42eb ... CBe_M93Rrv
Modified by 240sxdriftdaily at 8:21 PM 5/25/2005
GhostDrifter
Car: 91 240SX
I know this isn't on the Mani, but what about that little plate on the back of the head where all those hoses conected to? Can I remove that?
240sxdriftdaily
Yeas, I do belive those two sensors and maze of lines are removable. I junked them. I belive the went to the charcoal filter and other vac lines that now lead to nowhere. Not for sure tho, I dont thinks I'm puting the mani back on till I change motor mounts, oil lines press sensor,turbo, oh and body and paint. Then Ill let you know
JRL
Car: 1992 240SX Coupe
pr240sx wrote:There is also a small screw hole between runners 2 & 3 that secures the rod in place.
I noticed that too.
I was thinking about threading a vacuum fitting in its place. Anyone else try this before?
jack-pot
would this process be the same for the ka24e or what would be the differences? And, does anybody have any information on what all to remove from the SOHC? I want to remove the EGR, but i've heard it throws the EGR code.....is that just because people don't know what they're doing? Thanks
420sxse
Car: 92 s13se coupe
I'm kind of a noob when it comes to these more techinical detals, so excuse my ignorance. What effect will removing this stuff have on the operation of the engine? Will it throw off, say, the air/fuel mixture, or any other things that must be compensated?
hedgehog
Car: 1996 Nissan Altima GXE
Excuse me if it`s stupid question, but is it possible to change the intake manifold gasket, without taking engine of the car, because as I saw on pictures engine is of the car. Thanks!
1WheelWonder
Car: 1991 Nissan 240sx
What are the two plugs for, that are on the jungle gym-o-vacuum wires behind the head.
Chezedik
Yes, it is very possible. Just a matter of removing the intake and installing the new gasket. I assume there is more to this question.
hedgehog
Thanks for answer. There willbe more to that question, just a matter of time.Today I`ve tried some kind of sealer for intake manifold (10$). Doesn`t work. So, have to do something about it. But not sure I can do it.
uvamosk
the Pics are broke!! Can someone fix ... I really would like to see this :*(
pr240sx
Plate at the backYes you can remove it, 3 12 mm bolts
Intake gasket replacement engine in carYep, doable and easy
Will affect air fuel mixtureProbably BUT you have a O2 sensor that compensate for that. Usually the engine will have a higher idle speed afterward, mostly caused beacuse you cleaned all that soot and oily residue. No biggie, re-adjust idle speed via screw at the IACV.
Brackets holding the manifoldRemove them!, Slide the alternator and remove 2 14 mm bolts at the block. tube like bracket off.remove the plate like one so yu can slide toward the strut tower the mani. Its easier to remove the 2 bolts holding the bracket to the engine rather the mani to bracket bolts
Ezzo
Sorry to dig this thread up again but in 2nding the pics not working. Does anyone have them or can someone upload them again? It would be really helpfull for me and everyone else. Thanks
KATwo40
Car: 1993 240sx KA-T
Ditto. I'm doing a full KA-T build right now and would LOVE to delete some junk. Please, repost pics?
Thanks!
dsylvia
Car: 93 hatch
Foster's write up can also be found on my site, here
http://www.project-mayhem04.com/EGR%20Removal.html
frsh13
Car: 1991 240sx coupe
yo fiznat, could you get the pics up and running again. Im about to take off my intake manifold and could really use this info
Ezzo
look at Dsylvia's post right above yours
frsh13
Ezzo wrote:look at Dsylvia's post right above yours
lol thanx
fiznat
Car: Grown up :(
IMAGES FIXED!! Only took me a few months to finally get it right! :D :D
partymonster 975
Car: 03 Maxima SE, 94 Corolla
some one please sticky this, its a great post.
fiznat
Car: Grown up :(
partymonster 975 wrote:some one please sticky this, its a great post.
lol
Check out both my user title, and the "look here first!" stickied thread at the top of the page.
Thanks though bro
