Yes. The VQ37VHR makes ~330 hp.The new twin intake VQ35HR only makes about 15 more peak hp than the later VQ35DE. The VQ35HR's improvements were mostly in the areas of responsiveness and high-end power, not significant peak power increase.The twin intakes are partly responsible for the HR's better high-end performance, though.Soravia wrote:Isn't it the VQ37HR that puts 280+HP to the wheels?
I doubt it's that simple, unfortunately. Both VQ35DE and -HR use electronic "drive-by-wire" throttles. The TPS is integrated into the throttlebody. I think you'd have a hard time getting the VQ35DE's ECM to cooperate with the VQ35HR TBs.irax wrote:****, just try to get your hands on a VQ35HR upper/mid/lower intake manifold.
That's correct. He is prototyping a set up for the VQ35DE with a performance shop that's paying for R&D costs. I don't know which one but they will have the kits for sale there. Here are more pictures.http://i307.photobucket.com/al...79783h ... al...79872wrxratd wrote:^ extrude-a-body setup? More info please!!!!
Soravia wrote:I was just thinking about making a DIY individual throttle body set up for the VQ with 1995-1999 Manima manifold.
I figured that I could use the same set up as butterfly valves inside KA24DE thottle body and use it at the entrance of each runner. All necessary vaccume plugs would be split to each runner.For IACV each runner would be connected to a small box with the IAVC attached.
What do you think?
Magnum wrote: That's correct. He is prototyping a set up for the VQ35DE with a performance shop that's paying for R&D costs. I don't know which one but they will have the kits for sale there. Here are more pictures.http://i307.photobucket.com/al...79783h ... al...79872
wrxratd wrote:How much power are they expecting out of that? Apparently so much they need ANOTHER set of injectors mounted before the tb's...
