onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Mon May 26, 2008 10:39 pm
Fairly straight forward write up, but I figured at least one person may be interested in it (I was looking for one to no avail these past couple of months). This is a rear bumper exhaust heat shield install onto an aftermarket 240sx coupe rear bumper, but should be applicable to fastbacks, s14's, oem/aftermarket, and other cars.
Write up (links to larger pics) on my bloggy: 240sx rear bumper exhaust heat shield install
Total Project Time:This took me about 2 hours taking my sweet *** time with the hand / hack saw & 30 minutes of which was spent going to Home Depot to pick up rivets since I forgot where I put my other pack of rivets from way back when.
Tools:- Aluminum sheet (again, mine was .090" x 12" x 24")- Cardboard/paper for creating a template- Dremel, jigsaw, hack saw, or any other cutting tool you prefer- Drill w/ 5/32" & 1/8" bits, or whatever size rivets you want to use- Rivets & riveting tool- Dry erase marker or something to trace the template onto the aluminum- Optional: I also used a section of aluminum heat shield barrier with adhesive (used for protecting areas in the engine bay from turbo installs)
Step 1:I found it much easier to remove the rear bumper than to work with it on the car.
Failed attempt of using purely aluminum heat barrier with adhesive (ripped off @ Horse Thief Mile & took some paint with it).
Step 2:Create a basic template of what you want your shield to look like with cardboard or paper.
Step 3:Once you are satisfied with your mock up, trace the design onto the aluminum sheet.
Step 4:Cut away! I first used a dremel with the jigsaw attachment, but I ended up using an old fashioned hack saw. After that, I smoothed the edges with the Dremel w/ sanding & deburring attachments.
Step 5:Bend the aluminum sheet if necessary for your application. Then, test fit the sheet onto the bumper. At this point, you can drill pilot holes - drill onto the sheet first, then from there, drill through the bumper & place the rivets by hand to hold the position of the sheet.
Step 6:Finish up by riveting. In my case, I added the optional heat barrier at the bottom of the bumper so that I didn't have to bend the thick aluminum to cover that area.
Step 7:Reinstall the bumper on the car. Take some pics and go "oooo, aaaaa".
Don't mind the crooked rear bumper - just look at the heat shield, haha.
