How do i install an HID kit?
danwpg
Car: 2008 Rogue S
Hey guys, is there a diy somewhere for the install on the rogue? I found one on the altima that involves removing the front wheels and pulling back the wheel well.
from what I can see, I dont think that needs to be done on the rogue? is there a trick to this?
Looking forward to hearing what you guys did.
Thanks
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Check out this thread, I think it should help nissan-rogue-hid-projectors-t456091.html
danwpg
Car: 2008 Rogue S
Thanks alot for the link, it had some useful info in there, but nothing on the actual install? Unles I missed it?
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
danwpg wrote:Thanks alot for the link, it had some useful info in there, but nothing on the actual install? Unles I missed it?
i have installed plenty HID kits. in motorcycles, civics, maxima's, solara's, GS300's, etc.
it kinda depends on the kit you get. if its a plug & play kit - your pretty much plugging it in, and your done.
some crappy kits require you to strip wires, or insert little connecters into the headlight harness - not a big deal, but kinda annoying if you ask me. not a real secure way to do it - unless you strip wires and solder the connection right.
i would youtube some video's on how to do it- im sure someone posted it. its all pretty much the same, for every car. some cars have a cap on the back of the headlight (see picture below). you will have to drill a large, sometimes 1 inch hole into that cap in order to feed the wires out, and then use the supplied rubber gasket/grommet thats already on the wires to seal that hole (see the lowest of photo's to explain this)
Rogue One
2022 Honda Pilot SE
YouTube Videos = Install HID Conversion Kit
http://www.youtube.com/watch?v=dvhDGMUV4pg
NicolesRogue
Car: 2008 Nissan Rogue S
ebay plug n play hid kit, get the slim ballast, mounts easy.
Return to “Rogue Forum”
