DIY Glove Box LED Light
Leo2005
Since I replaced all my lights in the car with led the last one was in glove box. But after removing the light I found it was a really tiny light which is not only I couldn't find led like this but I couldn't find a replacement in local autozone. Took me 10 minutes to do all this.
There's 7 screws that holding glove box:
Remove the cover on the side:
Pull the box out and turn the connector to pull it out:
This is my new light from vleds http://www.v-leds.com/Exterior-LED/Cour ... 81144.html:
The connectors are different so cut the wires and test. Red goes to red(positive) and yellow goes to black(negative).
Make a good connection then stick the light to the same spot where original was and you done:
Nick 568
Car: 2008 Nissan Rogue
Very nice! Brighter than stock?
Leo2005
A lot brighter. Couldn't make a picture of original light since after removing that tiny bulb I lost it somewhere in a grass.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
I was about to replace the back-up bulb behind the circular lens in the rear. The only thing holding me back is the installation. I went to the rear and open the liftgate and removed those little plastic panels approximately behind the lens. Looking inside I was just all confused and said to myself forget it. It is probably easy to change but I never really do the electrical mods even though this is just an installation. I can change oil & filters, cabin filters, screw & bolt things on, stick 3M products, but electrical related stuff is my achilles heel.
The closest thing I have done that is electrical is plugging a cigarette adaptor to run my dvd player and GPS. :picard:
ThandaPani
Car: 2010 Rogue SL
This is a nice simple, yet great mod...Loving the LEDs
alisyed
Car: Nissan Rogue
How did you stick the light on? i order the same thing from the vled link you posted and its easy to wire it but how did you stick the light on? i haven't received the bulb yet. I changed all my bulbs too. all the dome lights and trunk are like a xenon color and vanity and the glove box are white so you can see better the vanity are white because the xenon is makes u look blue in the mirror and the glove is going to be the same. but the xenon bulbs i put on look really sick i will post a pic up soon
alisyed
Car: Nissan Rogue
casperfun wrote:I was about to replace the back-up bulb behind the circular lens in the rear. The only thing holding me back is the installation. I went to the rear and open the liftgate and removed those little plastic panels approximately behind the lens. Looking inside I was just all confused and said to myself forget it. It is probably easy to change but I never really do the electrical mods even though this is just an installation. I can change oil & filters, cabin filters, screw & bolt things on, stick 3M products, but electrical related stuff is my achilles heel.
umm its really ez i did it and im only 13. i can do electrical stuff i put a back up camera on my dads rogue and the reverse light does not need to be modif all you need to do is replace the bulb. ill show you a pic of my rogues back up light.
Leo2005
alisyed wrote:How did you stick the light on? i order the same thing from the vled link you posted and its easy to wire it but how did you stick the light on? i haven't received the bulb yet. I changed all my bulbs too. all the dome lights and trunk are like a xenon color and vanity and the glove box are white so you can see better the vanity are white because the xenon is makes u look blue in the mirror and the glove is going to be the same. but the xenon bulbs i put on look really sick i will post a pic up soon
There's a piece of 3M double tape on the back of it. I ordered with 6K color and I like it. Actually all my lights with 6K color. It is not really blue it is more white but yes it is kinda bluish.
alisyed
Car: Nissan Rogue
Okay i recived mines and installed it and its bright but its a circuit board led n i hav leds on the bulb. So lets share pics can i see a pic of all ur leds on ur rogue? Thanks!
alisyed
Car: Nissan Rogue
The bulbs i put hav a bluish light to it and the vanity n glove box are white because if i put those bluish bulbs on the vanity u cant see anything n same for the glove so i got white ones and the rest are like xeneon blue n white and when ur reading something in the dark its like the words are glowing n it shines the interior blue it looks really good but the white bulb tht we put on our glove is bright but i wish it was a lil blue cuz i hate the white its to plain
Leo2005
Heh..nice rephrasing the description but why for Versa not for Rogue? :)
Leo2005
Thanks. That's funny but I never thought about applying anything for the article.
kastenholz
Car: 2009 Rogue SL AWD
Did you have any trouble removing the glove box? I cannot gently pull the glove box out after removing the seven screws. Did you find any retaining clips that need to be pushed out first before pulling out the glove box? I am frustrated.
Adolph
Return to “Rogue Forum”
