DIY: FRONT GRILL DRL LEDs - 08 SEDAN
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
TexasMade89
Car: Nissan Versa 08
Athikerguy4life
Car: 2008 Nissan Versa
how did you wire them to turn on with the driving lights?
TexasMade89
Athikerguy4life wrote:how did you wire them to turn on with the driving lights?
i tapped into the parking light wires..
Aaron_versa2012
Car: 2012 Versa SV Sedan
MTX 6.5" speakers
Pioneer AVIC-x930BT
JBL GT1000D
Alpine Mono Block
Hey man,
Where'd you pick those up/ do you have a part number and $ for them?
Also how did you mount them?
AJVersa
Car: 2009 Nissan Versa S Hatchback
RE: DIY DRL
Since I rarely need foglights here it the Phoenix area. I decided to use mine as DRL.
I bypassed the foglight relay which is only activated with the low beam headlights on.
By inserting a jumper wire between a circuit energized by the ignition relay, and the foglight fuse. I now have DRL controlled by the ignition switch.
In the fusebox to the right of the battery. Fuses #48, #49, #50, #51, #54, and #55, are energized only when the ignition switch is in the RUN position. Fuse #56 is the foglight circuit.
I’m using LEDs in my fogs. They use much less power, and should last forever.
Return to “Versa Technical Discussions”
