neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Sat Jul 25, 2009 8:45 am
well my s*** hit fmu was bad my injectors saw 100psi at idle and they are still in use, I know a guy local ran 12psi on his t3/t4 setup and made some 300whp walbro fmu timing retard and balls.
In reality I have ran 12psi of boost with 70psi fuel pressure(had to be making 300whp I dont think I can drive or anything but it was a hand full!) and 5degrees knocked off the dizzy. Now running same 5* off the timing and the fmu,walbro,afpr. It is a hair lean for me right onto boost but the car is quicker now in that area for sure, I am going to add some base pressure with the afpr, to have more where I want it, then bleed off or some of the boost pressure to reduce the overall gain. But first I am going to redo the vac lines, I have the fpr,bov,and fmu on the same line... Now its fmu/boost gauge on the booster line and just the fpr and bov on the other. The fmu is also getting a smaller diam hose.
wd thanks it means a ton
I have ridden a horse, it sucks.
that is awesome send me more on that, I have a friend who is always complaining about his wireless while gaming, the lag is retarded.
we know, you pron fluffer
I am curious as to just how much myself, what can a single hp walbro255 put out? its ran on the relay mod btw. I think top feed would be more prone to get stuck, the S/F can basically free flow the pressure in between themselves rather than build up on top.. but IDK enough to make that call. I have 370's I am ditching in favor of the fmu. If I can get it to not max 80psi with 12psi I would run it daily damn that ran long
