Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Sun May 27, 2007 2:04 pm
Build the skeleton, kinda like this:
Click image to enlarge.
Now you will want to use a medium or high density fiberboard for the base and rings. For the legs, you can use any decent wood that is 1" x 1". After you build that, and set the rings where you want the subs to be, you will wrap it with fleece, stapling the fleece to the bottom. Staple the fleece around the rings. Cut the fleece out of the holes for the speakers. You want it to be tight and wrinkle free. Mix up the resin, and start painting it on. After you get some good coats, and it is stiff and dry, take a rasp and severely scuff the fiberglass around the rings ( the scuffs help the bondo to adhere to the glass). Use Bondo to fill the transitional places around the rings, and any air bubbles that you can see. Time to sand. And a lot of it. Wash well with a wet rag, and remove all dust left over from sanding. Use Glazing putty to fill all the micro air bubbles. Sand again. Work your way up to at least 600 gritPaint, and wet sand between coats to avoid "orange peel".Done. Install the speakers and enjoy!
Oh yeah, I forgot, you will want to cut port holes for the subs, usually 2"-3" and a square for the wire connections. Usually 2"x3". Use a router with a cutting bit to cut evenly and effortlessly.
