Rev_D21 »
https://forums.nicoclub.com/rev-d21-u4222.html
Wed Sep 16, 2009 3:01 pm
I was cruising Ebay and came across a Hardbody HD which has the most basic dash I'd ever seen, no radio. Just a plastic cover where the radio should be and this got me thinking...custom fit dash mounted gauge plate. I ordered the plate from my dealer, pt# 68470-60M00. At $9 I wasn't going to be hurting too bad if the thing didn't work out. If it did I'd have a plate built for my truck for less than 10 dollars. When I got home I marked everything out with my auto-punch, got my Dremel and my DeWalt out and a 2" hole saw then went to town. It came out exactly the way I wanted it to. I test fitted my old volt gauge just to be sure while I wait for my CBI gauges to arrive. What do you guys think of this?
Had to Dremel it out a little bit to make room for the hole saw. See the OEM screw brackets, that's Hollywood!
All I do to mount it is remove the cubby underneath the radio and replace it with this. Clean and OEM.
Modified by Reverend D at 9:02 PM 9/28/2009
