DIY: CD Box Lights - finished
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
jolyrojr
Car: 2008 Versa SL HB, Red Alert, Stillen front and rear valence lip, Stillen wing and exhaust, cold air intake XXR 001 wheels, footwell lighting, hand made red led dome, almost no amber lights anywhere!
I like that the cd box in the V is separate from the deck, because I have lost out on a cd box when switching decks before. Right 3now I have my center dash all taken apart, and I am messin around while I wait for my red 74 bulbs to come in (Im not going to put it together just to take it apart in a week).
I decided to light this part up inside, to make it a little easier to see way back in there. I started looking at different ways to do it because I dont want the lights on all the time, only when its open. After looking at the back I thought a switch would be easy enough, but I had a relay with a burnt coil, and decided that would be a fun way to go.
The door has an arm that connects to a spring to give tension so it snaps open and closed. I dremeled out a small circle on the end of the arm and glued in 2 rare earth magnets.
When the door is closed, the arm is up at the top
I cut apart the broken relay, and put it into a 69 kind of position with itself, so I would not have to remove as much plastic from the box. The door is open and the relay is making contact with the top.
When the door is closed, the magnet pulls the relay armdown away from the upper contact, breaking the circuit and turning off the lights
I would rather make a lens of some kind, but for not this works ok, I have to add a few more rows of leds though.
2 of the leds are not deep enough, but it works, I will work out the actual lighting later, the hard part is done!
I added more leds, 15 total, 1 row of 5 along the front, a circle and 2 in the middle, lots of glue to keep things solid and protect from shorts
here they are lit up from the top
from the front, showing the inside and the top
Last one, from the front, it looks kind of crazy, but I like it!
What do you think? (dont be to judgmental about the light quality, thx!) Maybe this will give some one an idea for another use of magnets and relays.
Codelicious
Car: 1989 Nissan 240SX
Its weird that no one has posted anything on this yet..
But anyways, great idea! It seems like a lot of work though. Keep us posted when you finish it :D
jolyrojr
Thanks! yeah it is a ton of work for pretty small results, but when business slows down, i have nothing but free time. Plus leds are soooo cheap! so why not put them everywhere I can, right? I have had a few setbacks here and there, but besides that its smooth sailing and im lovin the results.
The trickiest par was really just cutting up the relay to remove the coil without impairing function. I actually had a brain fart and cut off the wrong terminal but it glued together ok.
Codelicious
Looks like some pretty intense stuff. Do you do this stuff for a living?
jolyrojr
I do a lot of electronics repair and modding for a living, yeah. This is the first time Ive applied my skills to a car. This is the first car I really cared about modding. I love my versa, ill have this car forever!
Return to “Versa Technical Discussions”
