hub gives you a oem distance between the wheel and the turn signal switch, but when you add a spacer or QR. aint it a different story?sr20power wrote:so why is it JDM? because people been talking about it?...
i don't think you know what JDM stands for...do you?
but i guess i'll give you credit for making something....i guess...
hey you have small fingers don't you.....
ok if you say sochmercer wrote:are you an idiot. why is it usesless? it makes it easier to hit the turn signals. heres an experiment for you - go get a steering wheel hub. then put a quick release on it. then put a 75mm on it. then see how far your turn signal is away from your hand. WOW! its further away than stock! no ****! I wouldnt do this myself since i dont even use my turn signals that much but im not going to talk **** on the guy for doing a cheap mod that he likes.
someone needs to lay off the hatoraideAccord-240sx wrote:umm that would not be JDM. Anyways This must be the most useless mod in the world. Is the trun signal really that far away?? I mean it looks like something that a handycap person would have. I guess the next mod would be a carbon fiber ball on the steering wheel and some carbonfiber blocks to put on your pedles so your midget *** can reach them. HAHA as if the 240 arnt small enough.
Sure the turn signal stalk would be far away, but if I did all that, I'd have a bigger problem in that the steering wheel would be caving in my chest... Well, at least then I could steer with my pecs and use my hands to hold a drink, or talk on my cell phone...chmercer wrote:heres an experiment for you - go get a steering wheel hub. then put a quick release on it. then put a 75mm on it. then see how far your turn signal is away from your hand.
