DIY: Black out chrome
Member area: Post up your ride and the modifications to date
apexi957
Car: 2007 G35S
Didn't see a DIY for this, so I decided to post one up myself. This is my first attempt at painting and it didn't turn out so bad. I had the help of one of my other friend. Feel free to sticky this :D
Supplies
4 stacks of free newspaper
Painters tape
8mm socket (grill removal)
10mm socket (grill removal)
400 grit sandpaper
1x Rustoleum Automotive primer, paint and clear coat.
Prep Work
Get about 3 or 4 newspapers to do this. Cover the windows, body and anything you wouldn't want to spray.
Tape up the edges of the chrome trim so the stripping won't be discolored afterwards. Push the tape into the stripping, so you won't ruin everything later. Use a putty knife.
Painted the grill as well.
Covering is done
Do work son
http://sphotos.ak.fbcdn.net/hphotos-ak- ... 2551_n.jpg
Sand every chrome piece down with 400 grit until it looks like brushed aluminum
Apply 1st coat of primer to each side consistently or else it'll look off. I did 2 coats of primer.
1st coat of black after 2nd coat of primer dryed up. I applied 2 coats of black paint.
2nd coat of black on the rear spoiler
When the 2nd coat of black paint dries up. Apply a coat of gloss, then apply another after the 1st coat dries.
Grill done. Thats water by the way, not any residue from the paint lol.
Right side done. When the 2nd gloss coat dries up, pull away newspaper and pull off tape slowly.
Bad pictures, but I will upload some good ones tomorrow.
JDM angle yo.
Shenanigan
If theres anything wrong let me know. This is my 1st attempt, don't flame me hard. I ****ed up on some parts, but I'm going to redo it again next Monday or Tuesday
sniper27
Car: 2010 G37 sedan - Moonlight white/graphite
2008 M35 - Moonlight white/graphite
2011 Audi A6 3.0T - Ibis white/black
love it. that's how the car should come. i can't stand all that chrome trim.
apexi957
Car: 2007 G35S
sniper27 wrote:love it. that's how the car should come. i can't stand all that chrome trim.
Yeah chrome is garabge. Here are some better pictures.
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
has anyone had any instances where the chrome trim has rust where moisture has dried on it and left little brown rings. this is so annoying... i am afraid of long term damage.
sniper27
timmy0257 wrote:has anyone had any instances where the chrome trim has rust where moisture has dried on it and left little brown rings. this is so annoying... i am afraid of long term damage.
my Audi had the huge chrome surrounding the grill. i didn't have any rust or any discoloration issues with it in 4 yrs. i've didn't see any issues with my parents' previous mercedes either.
Wolvereen
Excellent job. :dblthumb:
apexi957
Car: 2007 G35S
I would think that it is all about prepping. If you sand every spot down and prime it then paint nothing would happen. Correct me if I'm wrong.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Nice job!!! :bigthumb:
Not a fan of chrome either especially on dark cars.
apexi957
Car: 2007 G35S
It's raining right now, so let's see how my paint job lasts. :D
EvilPanda
Car: '10 G37
that looks good. i recently painted the bottom bumper on mine, i might do the chrome on the trunk next.
sniper27
EvilPanda wrote:that looks good. i recently painted the bottom bumper on mine, i might do the chrome on the trunk next.
the bottom bumper? can you elaborate? pics?
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
i do agree with you. but i did not paint anything. i still have the stock chrome trim and I see small rust rings in it upon close inspection. i am still under warranty. i wonder if that would be covered.
EvilPanda
Car: '10 G37
sniper27
hmm...not bad.
joe603
Car: 2014 Durango R/T
Thanks for the write-up! I've been thinking about doing this to my car...let me know how the paint holds up.
apexi957
Car: 2007 G35S
joe603 wrote:Thanks for the write-up! I've been thinking about doing this to my car...let me know how the paint holds up.
It's pretty easy man, it's just a very tedious and long job. You should get some friends to help you because you'll need to wrap the trim up. The paint is holding up pretty well for the past few days. Nothings chipping and it's really hot and sunny in Atlanta, so if it hasen't chipped off yet then it won't be for awhile.
Good work -
Also, I'd add that after you tape up, and after you sand, go over the trim (BEFORE painting) with a cloth moistened with brake cleaner (to cut any grease or oils from your fingers). I ALWAYS wear gloves when working on my car, for this very reason.
I like the look!
cereal2k
Car: 2009 G37S Convertible,2003 G35 Sedan
Your car really looks good in person.
apexi957
Car: 2007 G35S
cereal2k wrote:Your car really looks good in person.
Thanks man! As does yours! It's inspired me to want a vert after this
cereal2k
Cool. Thanks :)
wsolo08
Car: 2007 Infiniti G35x
that looks really good, is there any special kind of paint you used, or just regular black spray paint like from home depot? im planning on doing the same thing with my black x. do you think i should match the color of the car by getting touchup paint from infiniti, or just get regular black?
also, about how long did it take to do?
sorry for all the questions!
apexi957
Car: 2007 G35S
wsolo08 wrote:that looks really good, is there any special kind of paint you used, or just regular black spray paint like from home depot? im planning on doing the same thing with my black x. do you think i should match the color of the car by getting touchup paint from infiniti, or just get regular black?
sorry for the late response. Just go to Autozone and get any automotive primer, paint and clearcoat. I will usually get Rustoleum if they have it in stock. Well your car is black anyways, so it just depends on what shade of black you want. It took me 5 to 6 hours because it was raining that day. Just ask me if your still confused
Return to “G35 and G37 Modification database”
