thaddes333 »
https://forums.nicoclub.com/thaddes333-u259840.html
Sun Dec 27, 2015 4:11 pm
Hello and thank you in advance for any help offered. This is my wife's Christmas present this year and it seemed pretty cut and dry. I have it all installed and am having an issue finding the wire that is going to the reverse light. I have to tap into this line to obtain power for the unit when the car is in reverse only. I have a good ground and can access the loom inside of the rubber boot that joins the door to the body. I pulled the light and there are 2 colors that go to the switch: Black and yellow. I figured Yellow would be the one to tap, but it is continually hot. I didn't tap the black one because I figured it was the ground. So any help or any links to the wiring diagram would be greatly appreciated. 2013 Rogue
