DIY, 90 Injector old style to 93+ new Style write up
icemaninlv
Car: 91 NA 300zx 2+2
Here you have the 2 different style injectors
Start by laying out this bag
then Start by stripping down to the lower intake
Layout your new injectors as shown
Place this with the oring on the bottom of each injector
should look like this, also notice the screen you can see the fuel hole
I put a touch of vasoline on the gaskets to ensure no pinching and then tightened down
Do this with each injector then reinstall your rail into the lower intake
I spliced and soldered all wiring after ohm checking the line directly to the ECU. Red wire to the thicker line.
Next due to the inconsitant voltage you need to rewire pin 58 on the ecu shown to a constant 12vdc supply. I used the clocks constant (yellow wire)
Run a wire down to pin 58 on the ECU shown
http://twinturbo.net/nissan/300zx/forum ... ryone.html
Reconnect your intake and you need to trim the injector near the oil cap. Just get something to grind it down otherwise you cant connect that injector.
Sorry it took so long to post, I broke my leg and my wife had a baby and I have been doing body work
greendusk
Car: 1990 300zx TT Pearl Glow (5 Speed now after swap)
1990 300zx NA Black Auto(Sold)
1990 300zx NA Purple 5 Speed(Engine Washed /Sold)
2001 Stratus (Scrapped)
where can this kit be picked up
icemaninlv
https://conceptzperformance.com/Cart/de ... hp?II=7731
I bought my injectors off ebay, make sure you research the person and brand prior.
Fireopal7
Car: 1990 300ZX N/A
Did you get your injectors from tmacaz? Little bit leery about price. Was going to buy and have tested before install, but if they work for you, they should work for me. Great post, thanks for showing the bridge grind picture. Most people just say it needs done and let it go at that. Picture=1000 words really applies here.
icemaninlv
