DIY 2006-2008 M35 DIY Cold Air Intake
CarGuy87
Car: 350z, G37s, M35s
Hello folks,
My daily is my 2008 M35S and it got boring all BONE stock so I wanted to post a DIY:
2006-2008 M35 cold air intake. (VQ35DE only)
Pros: True CAI does not pull in hot air from engine bay, low cost, great sound from the engine.
Con: Takes some cutting? Not sure here. Not CARB certified? Who cares!
Parts needed and cost:
1. Lower (and longer) portion of a 2003-2006 350z Cold air intake. $50 eBay part:
https://www.ebay.com/itm/Cold-Air-Intak ... 1271929877
2. 8" intake silicon hose (3" diameter) - $12 Amazon part: https://www.amazon.com/gp/product/B00TG ... UTF8&psc=1
3. 4x 3" hose clamps - $8 autozone
Total cost: $70
Total installation time: 20 minutes
1. Remove the air filter box
2. Cut MAF section and leave at least 1" for the clamp. https://1drv.ms/u/s!Akohwob0-eD2ga1b0cV ... g?e=CjrZpi
3. Take 8" intake hose and cut 2" out of it (pic 3) to use as a coupler. https://1drv.ms/u/s!Akohwob0-eD2ga1cVcT ... w?e=5eHI37
4. Use 350z intake pipe and hook up to long piece of the silicon hose (acts as a long coupler) with 2 clamps.
5. Connect clamp to MAF section you cut out, connect sensor.
6. Connect MAF section to 2" silicon coupler with clamp.
7. Connect clamp to OEM intake arm with coupler and clamp. https://1drv.ms/u/s!Akohwob0-eD2ga1fbhM ... w?e=ehmKW2
8. Do an idle re-learn procedure RECOMMENDED but not necessary and enjoy.
Quick 0-100mph run, all stock car just intake.
Ilya
Good work! I'll add this to the FAQ once I get some other issues sorted.
midnightclub619
Car: 2007 Infiniti M35x
This is an awesome DIY! and nice to hear your M still has all that push after your 145k mi. :bigthumb:
CarGuy87
Thanks, it is my watered-down daily but I enjoy cruising this thing. Next project is replacing a center console piece (missing when I bought the car) and "while I'm in there" wire up a full VDC delete switch like I have in the Z to get sideways in this thing!
Of course in this project you can get your own expensive K&N filter if your heart desires at a slight cost increase. In my case I had the Z intake so it was almost free.
1MeanM
Car: 2003 Nissan 350z
CarGuy87 wrote:
Thu Oct 24, 2019 8:24 am
Make sure you post a tutorial for the full VDC delete when you do it! I am looking to do the same, it would be very much appreciated!! Also, awesome job on the DIY CAI! :)
2007infinitim45s
Car: 2007 Infiniti M45 S
did you notice the car get any louder?
Larz
Car: 2019 Q70-L RWD
What a nice tidy job you did! Is it going to be a chore to change the air filters now?
CarGuy87
1MeanM wrote:
Mon Oct 28, 2019 2:46 pm
That is my next project. I have all the parts, just need to find the time!
2007infinitim45s wrote:
Tue Oct 29, 2019 12:24 am
Only at wide open throttle. The video does not do it justice. It's A LOT louder.
Larz wrote:
Tue Oct 29, 2019 5:20 pm
Actually, the opening from the engine bay to the inside of the bumper is MUCH bigger than my Z or G37 to such an extent that all it takes is removing the clamp on the 6" rubber piece then you pull the whole arm up in one piece. I was amazed at how easy it will be.
2007infinitim45s
Hi I came across a 350z air intake duct hose. I was just wondering if this would also work on the Infinti m45 2007 VK45DE engine?
