vibrating on high speed 100 km per hour and between 2300 rpm and 2500 rpm. when accelerator is on 3000 rpm it's gone.and if i remove foot from accelerator everything is ok as well.
Followed great link Thank you so much kkamakasi for write up and Towncivilian forPathfinder / QX4 General Information and FAQ!
I just replaced all sparkplugs with NGK PLFR5A-11(old ones had 1/4 inch gap
), cleaned throttle body,replaced air filter, and cleaned MAF as per Sticky and I still have same problem as you. fault codes are:
P1140 Intake Valve Timing Control Position Sensor (Bank 1)
P1320 Ignition Control Signal Circuit Malfunction
P1490 EVAP Vacuum Cut Valve Bypass Valve Circuit Malfunction
and finally P0300
I don't think problem is gone when accelerating I'm guessing when I kick out of Overdrive, RPM goes up and roughness smooths out.
Paid $1000 for it last Feb, week later Son hits fire hydrant passenger door and fence(only snow we had last year and he found it). took out small dent in Aframe, replaced passenger floor and door, bottom half door hinge frame, both rocker panels, rusted wheel wells, both front fenders. What a tank. Cost me another $1000-1200 for replacement parts, welding and paint supplies. 6 months later it works but runs rough.
I'm going to try the trick of disconnecting one coil at a time and notice when it runs worse, if I get a warm day.
