krayton »
https://forums.nicoclub.com/krayton-u8223.html
Fri Feb 16, 2007 9:49 pm
Ok, this might sound complicated and wierd.
first off, if i wanna ditch the stock water oil cooler (rb25), can i just plug up the lines that go through it. or do i have to bypass it (so the water lines go to the block hole: thermo -> block hole near rear.
ive already taken out my heater so all thats under my manifold now is thermo -> oil cooler - > hole on block.
secondly, if i leave the oil cooler on there, will it negatively affect my oil temps when i upgrade to an air oil cooler. for example, the water oil cooler holds the air oil cooler from cooling efficiently.
any help on this topic would be great
