Hey,
I'm pretty new at turning spanners on cars with EFI.
I have a '95 U13 bluebird, with an SR20de. (Picked it up too cheap not to buy it)
The seller reckoned it had speed cut at 180km/h. I'd like to remove this. A friend who's pretty clued up with CA18's, tells me that the ECU would be costly to modify to do this. (Have to buy a NIstune Daughterboard or some such) Or I could just cut the speed sensor wire to the ECU. I know a little bit about (as in a little, not a lot) about how ECU's use the engine sensors to do their thing. Does the ECU need the VSS signal to work properly? The engine isn't a VVT version, so it wont be relying on it to work that.
Does the speedometer feed come from the ECU?
What do you guys think?
