KoopaTroopa »
https://forums.nicoclub.com/koopatroopa-u128221.html
Thu Aug 19, 2010 10:08 pm
while trying to find if anyone had the same problem as me i found this post on zilvia
"i put a 97 head onto my 92 block and did all the timing chain things. im sure i did the timing chain correctly, i triple checked everything. but when i try to put the distributor back in, it goes up to the ring and gets stuck. i tried taking off the ring and its still stuck. it only goes in when i turn the crankshaft with a socket wrench but when i turn it back counterclockwise it comes back out.
and once i put it in it gets stuck inside and its hard to turn it. i put wd40 all over it but it still doesnt help. anyone have any ideas? any help is appreciated. thanks"
I just put in a refurbished ka for a 1991 240sx and when i went to put my old distributor in it gets stuck in the same exact spot. Only way to get it in is to turn the crank as the guy said. Something must be wrong, it was never that tight to get in, it really wont budge.
