edit: I just read your post again. I see now that your OLD dizzy has 5 wires and the NEW dizzy has only 4. Based on my Haynes manual, 4 wires should be correct and are connected as I described below. Sorry for any confusion in my last paragraph below.
tfranchise2k wrote:Hi guys. I'm new to this cool site so please forgive me if I'm asking a question that someone has already answered, but I have a 1984 Nissan 720 and I needed a new distributor. I went to the auto parts store and picked one up. When I went to take off the old distributor I noticed it had 5 wires connected to it, but the new distributor only had a place for four wires. I'm not the original owner of the truck but to my understanding the 2.4L was the only motor that they put in the king cabs. So my question is that is it possible that the motor in this truck is the 2.0. It has 8 spark plugs, and I replaced the alternator a few years back, but after I did some cross referencing I found out that both motors use the same alternator. Does anybody know if the 2.0 has 5 wire connections. Thanks to anybody who reads this.
OK, first off, at one place you said distributor and another you said alternator. If I get the drift of your question, then you are talking about the distributor and not the alternator.
The dizzy cap will have 10 towers, (8 for plug wires and 2 for the coils).
My Haynes book has a general wiring diagram showing only 4 wires coming from the dizzy. Three go to the terminal junction block and another single BLACK wire that goes straight to the condenser.
The 3 wires from the dizzy to the junction block are as follows:
Black with white stripe - this terminates at the fuse box
Red - this joins to a red wire coming off of the negative pole off one of the coils
Blue - this terminates at the negative pole of the OTHER coil
I think you should talk to your parts supplier and see if they have a new dizzy with only 4 wires or at least tell you where to hook that 5th wire.
