Fsmyles »
https://forums.nicoclub.com/fsmyles-u158310.html
Mon Apr 12, 2010 5:33 am
I looked through the archives for this answer and couldn't find it.
During the weekend, I replaced the spark plugs, spark plug wires and distributor cap of my '98 Pathfinder. Wish I had known about the tool kit under the rear seat on Saturday. #6 was tough, but after 2 hours, I was able to repeatedly able to find the spark plug with great ease. I can't tell you how much I learned about my Pathfinder - well, actually I can, but that'll require lots more typing.
Anyway, I was also going to replace the rotor under the distributor cap but could not get it off. Yes, I did remove the set screw. I tapped the rotor with the handle of a screwdriver to try to vibrate/ knock it loose - no luck. Anyone got a solution? Not sure if I should use a lubricant or WD-40 to help. I am pulling straight up. Not much around to offer a leverage point.
Frankie
