Distributor Removal
high flya
Car: 1993 S13 240SX SE Hatchback (Project)
2002 E46 M3 Coupe (Depleting my $$$)
2015 YZF-R3
2011 BL Mazda3 GX Wagon (Beater 3)
I apologize for not having too much know-how, so please bear with me.
I'm following the excellent walkthrough on fixing the chain rattle on my '93 HB. But I'm having real difficulty with removing the distributor. More specifically, how do I unplug the sensor wire plug (I pulled on it pretty hard and it won't budge), and how do I pull off the distributor cap (those plastic clips look fragile)?
Specific and idiot-proof instructions will be much appreciated.
NISTECH
You have to squeeze the tab on the connector to release it. The clips holding the cap? There should be 2 phillips screws holding it on.
I dont want to dog you dude, But if you are having these kinda problems with the basics maybe you should enlist the help of a freind who has at least some mechanical knowledge. The only reason I say this is if you slip with the chain alignment you could have a problem with bending valves. Again not trying to be negative just tryin to help you out.
Good luck on the job and welcome to nico
high flya
2015 YZF-R3
Thanks dude, I'll give it a go.
