DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sun Jan 15, 2006 4:11 pm
no, it can be anywhere.
it has helical gears so i can only assume you are twisting it while pulling it out right?
i had one so bad on a junk motor i have, that while trying to remove it, it broke at the base where the shaft meets the bottom of the base. if your motor is exceptionally dirty or you dont maintain it well, nastiness can build up between the walls and the shaft preventing it from coming out.
i just shake it a little while twisting back and forth while pulling it out, sounds sexy doesnt it.
the rotor should twist automatically while you are doing this, but you should be worthing the shaft clockwise and counter clockwise while pulling out
