Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Jan 25, 2008 10:30 am
Being 180 degrees off in timing is simply that your distro is trying to fire the proper cylinders at the wrong time. Normally, they'd fire at TDC of the compression stroke. Given that the crank must make 2 full revolutions (one for compression, one for expulsion), the CAS turns at a .5:1 ratio. (For every two rotations of the crank, the CAS rotates once).
Now, when things are working right, the crank will make its 2 revolutions and THEN the distro will have made its 1 to fire at TDC compression. However, if you're off 180 degrees, the distro wants to fire at TDC exhaust stroke. Which is the wrong time. All you get is a motor that cranks, holds compression, has fuel, and spark, but won't start. The telltale sign is usually you'll hear a backfire or popping noise through your intake tract as the spark plugs try to fire during the overlap time that the valves are opening.
The easiest fix for this is to set up your CAS timing like normal, then rotate it over a half turn (180 degrees) and then insert.
However, every distributed SR20 I've seen in RWD configuration has utilized an integrated coil ontop of the distributor, not a seperate coil that the S13 KA24DE utilized.
