Post by 300 z man » https://forums.nicoclub.com/300-z-man-u74177.html Tue Mar 18, 2008 2:32 pm
Post by AZ-ZBum » https://forums.nicoclub.com/az-zbum-u9212.html Wed Mar 19, 2008 1:47 am
Turn engine over until the timing marks on the crank pulley are at 20 degrees BTDC. Take off cap. Note where contact is for cylinder number 1. Make sure rotor is pointing at that contact point.300 z man wrote:I put my 300 zx back together and can get it started but it looks like my timing is off a bit. I have it adjusted all the way over but I think I may be off a tooth on the gear. What do you guys think? Also, does anyone have a diagram of vacuum hoses? I think I have a vacuum leak.
Post by 300 z man » https://forums.nicoclub.com/300-z-man-u74177.html Wed Mar 19, 2008 1:23 pm
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
