abc123omg wrote:i believe the Japanese 240sx had diff "trims", and the higher trim had the sr20deT with the turbo, and the lower ones can with the sr20de non turbos which used a distributor setup.
i used to have one and was about to turbo it but sold it instead lol.
and i think the diff (aside from distributor and coilpacks) between the sr20 DET and DET is that the DE has 9-9.5:1 compression compared to the DETs 8.5:1
and also you can get a rwd sr20DE motor and transmission for like 800$ (last time i checked)
S14 N/A SRs are 10:1not 9.5:1
N/A SRs came in Silvia Q's in Japan
